Old 07-08-2013, 04:14 AM   #1
JCampbell
Vehicle Speed Sensor
Quick question.
'84 C10. Originally came w/ a 305 and 700R4. Would I have a VSS (vehicle speed sensor) already? What does it look like/where is it located?
I was under the impression the 700R needed VSS for TC lockup, so I'm hoping I already have one. In the middle of a TBI swap and I need to get one if I don't already have one.
JCampbell is offline   Reply With Quote
Old 07-08-2013, 10:33 AM   #2
Jonboy
Slots go on anything!
Re: Vehicle Speed Sensor
You should have one. I used a VSS from Jags that Run when I did mine- the 2PRS.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-08-2013, 11:21 AM   #3
Desert1957
Desert1957's Avatar
Originally Posted by JCampbell View Post
Quick question.
My 1983 Chevy van had this vacum switch setup, like in this pic
due to the engine vacuum constantly opening and closing the switch , converter lockup was always in and out , kind of annoying.
Desert
Desert1957 is offline   Reply With Quote
Old 07-08-2013, 03:29 PM   #4
hatzie
Moderator
hatzie's Avatar
The 700R4 had a vacuum controlled TCC like ^^^
If your 83 has VSS it's off the speedometer for the overly complicated early 1980s electronic cruise control system.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-08-2013, 04:21 PM   #5
MalibuSSwagon
Do you have factory cruise control? If so, you should already have a VSS on the back of the speedometer.
This is what it typically looks like.
Pink/Black stripe - 12V+ ign
Black w/ white stripe - Ground
Brown - 2k PPM output to ECM
Extra yellow connector - 2k PPM output to cruise unit.
You can get these optical VSS units off any 80's car or truck with cruise, or TBI; or both. Mine was from a 84 El Camino.
You'll see this if you have no VSS. Any 81+ GM speedo has the provision for the optical VSS. Get the little screw too, you'll need it.
These pics are from when I installed a VSS for my TPI conversion in my 86. Works flawless, but grab a few from the pick a part, my first one didn't work, these are close to 30 year old electronics. They are easy to find. Pull the cluster, and trace the 3-wire ribbon back to the green (or yellow) box. Get the whole thing including pigtail, You'll need a small 5.5 or 6mm socket for the screw in the speedo.
MalibuSSwagon is offline   Reply With Quote
Old 04-28-2014, 10:20 AM   #6
Hotrod1952
I know this thread is a little old but... How does the cruise control use the speed reference? In other words I want to use a Jags 2prs on my 87 to replace the green box behind speedometer. Do I hook the yellow and brown wires to the 2prs and ground the other wire on the 2Prs? I would like the ECM to use the reference. And I want cruise to work.
Hotrod1952 is offline   Reply With Quote
