Old 07-08-2013, 09:52 AM   #1
Gus350
68 C 10
Gus350's Avatar
Door handles
My next door neighbor gave me some handles this weekend one has a shorter collar on it can you guys tell the difference in these two handles.
Thanks KevinName:  image.jpg
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 07-08-2013, 11:58 AM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Door handles
Rear handle for Suburban or panel?
NEWFISHER is offline   Reply With Quote
Old 07-09-2013, 08:40 PM   #3
oldcouple
oldcouple's Avatar
Re: Door handles
The longer shaft one is from a 60s truck, I know because I bought a set with matching keys at the junk yard and had to cut them down to fit the 56. They started putting locks one both sides in the sixties, until then it was only the passenger side, so you could not get in the habit of getting out in traffic when parked.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 07-10-2013, 12:03 PM   #4
Gus350
68 C 10
Gus350's Avatar
Re: Door handles
Thanks so the one with the short shaft is preo 60 truck then.
Kevin
John Wayne
68 C10
70 C20
Old 07-10-2013, 03:37 PM   #5
oldcouple
oldcouple's Avatar
Re: Door handles
Yes but you can swap the lock set itself to either handle if you want to add the locking part instead of button only, you just have cut the actuator shaft if going to pre 60.
