Old 07-08-2013, 11:23 AM   #1
budnikguy
budnikguy's Avatar
Dana 60 Rearend Posi complete 4.10
Dana 60 rearend, power loc posi, 4.10 gears, removed from a recent running/driving '67 GMC. 3/4 ton 2wd 8 lug with leafsprings. Prefer local sale, can hold, as long as paid in full. This is complete with leafspring pack and rear brakes, bolt in and go.. I have this for sale locally as well. $250. May be open to shipping, if that can be arranged by the buyer...up for trades on this also!
Adam
budnikguy is offline   Reply With Quote
Old 07-12-2013, 04:00 PM   #2
budnikguy
budnikguy's Avatar
Re: Dana 60 Rearend Posi complete 4.10
end of the week bump....open to trades too!!
Old 07-13-2013, 12:05 AM   #3
Critterman71
Critterman71's Avatar
Awesome price for the 4.10 Posi axle if I was close I would own it. If it does not sell let me know I would be open to just buying the posi unit and gear set shipped to 48872. Some body should pick up the whole thing though if not let me know
Critterman71 is offline   Reply With Quote
Old 07-13-2013, 12:55 AM   #4
swamp rat
swamp rat's Avatar
Ca you share how you know it's a posi? Is there reference charts? Just want to learn a little.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-13-2013, 01:02 AM   #5
Critterman71
good question as i dont see the original limited slip tag on the cover section across from where the 41-10 ratio tag is but they get torn and bent easy over the years and are lost. To tell if it is a posi/limited slip with the wheels of the ground spin one wheel preferably the left one but either will wok and if both wheels spin the same way at the same time it is a posi/limited slip rear.If one wheel spins the opposite way you are spinning the other wheel it is more than likely an open non posi rear end
Old 07-13-2013, 01:04 AM   #6
Critterman71
with out pulling the cover to see the actual unit which is distinct in appearance that is the easiest way to tell
Old 07-13-2013, 01:18 AM   #7
Critterman71
American pick up a member here on the board has a posting showing a 4.10 non posi with the case cover off. (1972 C20 disc brakes and 4.10 dana 60 rear) is the post you can see the unit where the ring gear is even though it is slightly turned downward it has no clutches in the center of it just spider gears on both axle sides ans no other locking mechanism is present as there has to be something to lock both axles together and there are several types of locking or limited slip differential sections. the one pictured in the post is a Dana 60 open carrier/non posi rear. hope that helped and was not confusing.
Old 07-13-2013, 09:42 AM   #8
swamp rat
swamp rat's Avatar
Thanks for the info!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-14-2013, 10:49 AM   #9
budnikguy
budnikguy's Avatar
After a little more clean up, the limited slip tag....
Old 07-14-2013, 10:42 PM   #10
Critterman71
swamp rat if you need one like this you should jump on it these things are indestructible and are worth every penny. If I was close I would buy it and hang on to it.
Old 07-15-2013, 10:09 AM   #11
swamp rat
swamp rat's Avatar
Thanks but i'm not close enough to go get it. Plus i would also need a front as i have 4X4.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-15-2013, 06:30 PM   #12
MadnessBigBlock
Interested in the gear and posi unit if you split up.
MadnessBigBlock is offline   Reply With Quote
Old 07-23-2013, 01:34 AM   #13
budnikguy
budnikguy's Avatar
Update...willing to sell just the posi and gears...still a heavy piece to ship...but, probably reasonable via Greyhound...
Old 07-23-2013, 08:41 AM   #14
Critterman71
What is it shipped to 48872 thanks Chris I asked about them in post #3 For the gear and posi unit.
Old 07-23-2013, 09:44 AM   #15
budnikguy
budnikguy's Avatar
Chris, do you have a Greyhound terminal to ship to? If so, let me know your local terminal that accepts packages and we could go that route to keep shipping affordable! If not, I will get a FedEx quote.
Old 07-23-2013, 10:06 AM   #16
Critterman71
There is a greyhound terminal in Lansing mi package express
Address: 420 S Grand Ave, Lansing, MI 48933
Phone517) 482-4246
Hours: Tuesday hours 8:00 am–5:30 pm - See all
Old 07-23-2013, 10:29 AM   #17
budnikguy
budnikguy's Avatar
Estimated it at 100 pounds, and the Greyhound site states 102 and change to ship..if that is accurate, I would go $425 delivered to you...
Adam
Old 07-23-2013, 10:17 PM   #18
MadnessBigBlock
Gear and posi unit shipped to 58265?
Old 07-23-2013, 10:36 PM   #19
budnikguy
budnikguy's Avatar
is Greyhound and option for you? If not, shipping via FedEx...I could eat some fo the shipping too, and go $445 delivered.
Old 07-26-2013, 08:22 PM   #20
budnikguy
budnikguy's Avatar
back to the top....
Old 07-28-2013, 11:02 PM   #21
Critterman71
sorry for the delay thanks for looking into the shipping I want it but with the shipping I can get new one shipped to me for less. But hang in there some one will pick this up for sure. I would be willing to take just the carrier with out the gear set. it weighs just about 42 pounds give a take a pound with out the gears. I would do that if it gets down to it if now one else grabs the whole thing with the gears. keep me in mind. Chris
Old 09-05-2013, 08:36 PM   #22
JOJABOY
I'm in L.A. Are you willing to reduce price a bit if I come pull the axle from the leafs and drive away with it?
JOJABOY is offline   Reply With Quote
Old 09-05-2013, 09:06 PM   #23
budnikguy
budnikguy's Avatar
Yeah definitely, I can pull the leafs and have the axle ready to go... hit me up here, call or text me 951-544-0721
Adam
Old 09-24-2013, 07:21 PM   #24
budnikguy
budnikguy's Avatar
Ttt
Old 09-24-2013, 08:13 PM   #25
tlcrz1972
tlcrz1972's Avatar
Go through Fastenal to ship, they are reasonable. They don't give a date of delivery because they move it when there is room.
I shipped 175 LBS to NY for $125
The biggest thing is they only ship store to store. But for the savings it worth it.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
