07-08-2013, 10:53 PM | #1 |
Question about Engine fit
I have a 1964 C10 and just got a line on a 1988 302 Engine and Transmission out of a camaro... decent price but how much of a headache would this be?
I am brand new on this site so if I am asking something that could be found elsewhere, let me know. Thanks, Alan |
07-09-2013, 12:09 AM | #2 |
Moderator
Re: Question about Engine fit
That "302" will be a 305. Either the weak TBI or the slightly less weak TPI. Better engines out there, keep looking.
07-09-2013, 12:17 AM | #3 |
Thanks. That's the kind of stuff I need to hear.
Posted via Mobile Device |
07-09-2013, 02:10 AM | #4 |
Senior Enthusiast
Welcome to the forum!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
07-09-2013, 07:54 AM | #5 |
I too am weighing engine options... Seems like any post 86 truck 350 - up to and including the Vortec engines - are the "way to go", at least for me. There are TONS of these engines in every U-Pull-It I go to, so they are readily available. These engines are also known for minimal bore degradation (I've heard this is due to improvements in the FI system but cannot verify). As a result, I've seen more than one "refreshed" by simply changing the rings, bearings, and gaskets. Lastly, this block design allows for the use of a roller cam, which leaves plenty of power potential for the future. Granted, this is probably the most boring engine to use in a truck, but I am more interested in function over form... To each their own, and good luck!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
07-09-2013, 07:59 AM | #6 | |
These engines are not that bad, infact the heads are used alot on performance engine, because of some good flow characteristics and smaller combustion chambers. The later 305's are not as failure prone as the earlier ones. Mine's got 240K on it with no major internal repairs, just basic maintenance. |
07-09-2013, 08:02 AM | #7 |
1965 Chevy C10, 2005 4.8L/4l60
Alan, I would pick up a 4.8 and a 4l60e for your truck, those are much better motors and you can usually snatch them up under $1k with trans and engine, under 80K. they will run great past 200k miles as long as you take care of them and you will improve you mileage and in turn have a more reliable and fun truck. just my .02 but im also biased!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-09-2013, 09:16 AM | #8 |
I seem to learn something new every day. I always thought the 302 was a Ford specific but apparently: "The 302 engine was only available in first-generation Z-28s (the 350 LT-1 was used in 2nd generation Z-28s), and was created in response to a Trans Am racing engine displacement limitation at that time of 5 liters (305ci). The 302 was created by installing a short-stroke 283ci engine crankshaft in a 327ci block, resulting in 302ci displacement." When I was originally told it was a 302 I said it was a Ford... Then I was enlightened. Overall I am looking for function over speed and I am soooo new in the whole process. Lots of AMAZING builds on here... I strive to be worthy... |
07-09-2013, 09:29 AM | #9 |
Chevy addict
I have a 305 (rv cam, Edelbrock carb otherwise stock) and 700r4 from a 86 Camaro in my 56 Chevy Belair, with 3:55 rear end it goes really good, 22mpg
07-09-2013, 09:37 AM | #10 | |
07-09-2013, 12:35 PM | #11 |
Moderator
I agree, however, for the same price, and same labour, you can put in a TBI 350 that has more power, and will get the same mileage. Also, if you choose one from a car (Caprice, Roadmaster/Fleetwood, 91-93), you get a roller camshaft, while the trucks got the flat tappet cam. A good consideration in these days of reduced ZDDP additives in oil.
07-09-2013, 01:58 PM | #12 | |
07-09-2013, 02:34 PM | #13 |
My 305 came out of a 1991 Olds Custom Cruiser wagon-same as a Roadmaster wagon, etc. It is not a roller cam motor, I don't believe.
07-09-2013, 03:50 PM | #14 |
Moderator
The cars got roller cams, the trucks didn't. Not just the 9C1 option (police) L05. Interestingly, that cam is the exact spec cam used in the L98 F/Y (Camaro/Corvette) TPI engine. A stock LT1 cam (from a Caprice/Roadmaster/Fleetwood), while small, is still a great upgrade for an L05 engine. Designed for low RPM torque. Slides right in, and most LT1 guys will give them away.
07-10-2013, 05:00 PM | #15 | |
Sam |
07-10-2013, 05:09 PM | #16 |
Who Me?
I have no issues or complaints with my 305. If the price is right, go for it!
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
07-10-2013, 05:15 PM | #17 |
Have you considered a brand new crate motor ? Jegs has a basic 350 with free shipping for about $1500,
07-10-2013, 06:17 PM | #18 |
Chevy addict
Yup, 301s and 331s rule man !
07-10-2013, 06:43 PM | #19 |
I have a 1991 350 in my "63 ..I love the serpentine belt and the fact that now I have power steering and a mount for the AC... bolts in no problem....
