Old 07-08-2013, 11:19 PM   #1
restorationboy14
got a few questions on a truck im lookin at!!!
Alright, I have a 69 GMC and would like to add to my collection, Im looking at buying a 60-66 Chevy c-10 2 wd 3 on the tree. I climbed in and it smelled like mice, no biggy. But I pushed on the clutch and it had GOOD PRESSURE!!! it was last liscensed in '02. The brakes are a different story, I pushed and had little resistance, then just was completely free of pressure, Could I have pushed all the junk in the master cylinder into the lines? or was the brake piston just alittle seized up? The wood bed is in AMAZING STOCK CONDITION!!! So my main question is. Is this worth 400 bucks? And how difficult are the brakes on this truck? But my question at the top of my list is this, What is wrong with the brakes???????? it has a I 6 in and looks like a 250. is that correct?? Im very excited about this truck. Thus the reason for all my run on ??????? marks haha. Thanks guys!!!!!!
restorationboy14 is offline   Reply With Quote
Old 07-08-2013, 11:40 PM   #2
chevyman95
chevyman95's Avatar
Re: got a few questions on a truck im lookin at!!!
Buy it for $400 all day long, that's scrap value around here.
chevyman95 is offline   Reply With Quote
Old 07-08-2013, 11:55 PM   #3
66Submarine
66Submarine's Avatar
Brakes are just normal drum brakes, same as your '69. Easy to work on, and parts are cheap and readily available. Expect to at least need to rebuild or replace all the wheel cylinders and maybe master cylinder. (I just buy the rubber seals and rebuild them, personally.) Stick some new shoes on when you fix the wheel cylinders, too. FWIW I don't turn drums. Make sure the lines and hoses are good, it's not a bad idea to replace them anyway. I get a lot of brake stuff from Rock Auto, btw.
66Submarine is offline   Reply With Quote
Old 07-09-2013, 12:10 AM   #4
restorationboy14
That's what I was planning on doin. I want to replace the MC and then clean out the lines, then redo the shoes.
Old 07-09-2013, 10:40 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Does it run? And is the clutch hydraulic or mechanical? 1960-1962 were hydraulic, 1963- were mechanical. Brakes if stock should be drum so no biggy on replacing those. What year is it? 250 was an option from 60-78. If it runs and doesn't have rot then 400-550 is an okey offer. Keep us posted.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-09-2013, 11:17 AM   #6
McCoyAZ
McCoyAZ's Avatar
Parts are worth more than $400
Buy it
McCoyAZ is offline   Reply With Quote
Old 07-09-2013, 11:50 AM   #7
chevyrestoguy
chevyrestoguy's Avatar
$400? You haven't bought it yet? If not, get it before somebody else does.
Friends, the days of finding a cheap '60-'66 are rapidly coming to a close. If you've always wanted one, I would suggest getting it as soon as you can because the prices are climbing rapidly.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-09-2013, 10:58 PM   #8
restorationboy14
This truck is not publicly for sale. Its between a friend and I. Ok so I should jump on this deal??? Thanks!!!
Old 07-09-2013, 11:00 PM   #9
restorationboy14
Alright so my main question is this, how do I get the brakes in working order? Does the dead pedal mean the MC is bad??
Old 07-09-2013, 11:07 PM   #10
jayoldschool
Moderator
Did you look IN the master cylinder? No fluid=no pressure. It could have leaked out from a bad line or wheel cylinder. If there is fluid, start looking at lines and wheel cylinders.
jayoldschool is offline   Reply With Quote
