Old 07-09-2013, 04:00 PM   #1
skorpioskorpio
72 door panels in a 70.
What is the difference in the doors between a 70 and a 72 and how does that effect the inner door panels. I am going to end up replacing most of my door internals anyway, but I don't know if the basic structure of how the inner metal door skin is laid out is vastly different, I just know some of the parts and the panel itself are different.
skorpioskorpio is offline   Reply With Quote
Old 07-09-2013, 04:07 PM   #2
nightmare
nightmare's Avatar
Re: 72 door panels in a 70.
besides the obvious door panel difference, the only other one is that the 72 doors have a screw underneath the wing window to keep the door from separating. other than that, all other parts are the same
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 07-09-2013, 04:16 PM   #3
skorpioskorpio
Are you refering to this screw?
Old 07-09-2013, 04:17 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I think the '72 doors also had different length shafts for the window crank and the door handle than '67-'71.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-09-2013, 04:27 PM   #5
nightmare
nightmare's Avatar
Yes
Mike
67-72 FAQ
Old 07-09-2013, 04:38 PM   #6
Scott>72-GMC
Scott>72-GMC's Avatar
Yes handles and cranks are longer to go through the 72 style door panel
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 07-09-2013, 05:07 PM   #7
skorpioskorpio
So basically if I change to 72 regulators and handle relays, it's a '72 door?
Old 07-09-2013, 05:51 PM   #8
J kippin
J kippin's Avatar
if you want to install the 72 style panel use the regulators for the door and window for that year. other than the additional screw hole they are they same. The screw gave the door a little extra strength around the window divider post.
J kippin is offline   Reply With Quote
Old 07-09-2013, 10:27 PM   #9
skorpioskorpio
Mine seems to have that screw (in the pic above) and it's a '70.
Old 07-09-2013, 10:44 PM   #10
nra4life
Skorpio, I put '70 doors on my '72. As others have said, you will need '72 window regulators ( longer shaft ) I had my body man put the '72 dents under the vent windows. That little screw really stiffens the door. If you decide to put the dents in your doors, don't forget there is a flared chromed tube inside the door so the screw can't pull the inner and outer panels together when the screw is tightened. It helps keep the mirrors from vibrating at highway speeds, too. Also, the '72 door panels have all their mounting holes in different places. They all have to be redrilled in the doors. And the '72 door panels use a lot of barbed plastic studs to fasten the panels to the doors. Roy
nra4life is offline   Reply With Quote
Old 07-10-2013, 09:34 AM   #11
Only 72 doors had that screw. Other than that the doors are identical. All door guts interchange between 67-72. You can put any year door panel on any year door as long as you use the window and door handle shafts made for that year door panel. And,'72 door panels are the only ones that need the same year shafts,no matter what door you use.
Old 07-10-2013, 01:47 PM   #12
skorpioskorpio
I guess this screw is not the screw we're talking about in the '72 door:
Name:  IMG_1408_wing window screw.jpg
because this is my '70 doors and they have this, it is a Jimmy and not a cab just so that is clear.
Also to clarify, the panel mounting holes are different? So I'd need to drill those holes in my inner skin for those, correct? ...and those holes are for blind clips? Are they the typical barbed plastic type used by GM for years with the 3/4 disk head? Are the arm rest cage nuts from the earlier doors used in any way?
I was also curious, who was a good source for reproductions of the '72 panels? The ones from LMC seem like they are different then the originals in that their woodgrain sub panels say they do not work with them, but only on original panels. Also LMC lists their woodgrain sub panels as plastic where as the counterpart ones are listed as aluminum, what are the originals? Are all these aftermarket panels the same? I like the more sculpted bottom of the '72 panels but am not wild about the decorative scroll work on them, and would like to maybe use the woodgrain inserts, recovered in upholstery to match the seats, to smooth them out a bit there. What are my options?
Old 07-10-2013, 02:05 PM   #13
29od1
The Blazers and Jimmys pre 72 had the screws as you show, but no pickups. It's just a hole that's drilled and the plastic grommet fits into it to reinforce the door in that local area since the Blazer/Jimmy window frame only goes to the top of the wing window.
In 72, they added the dimple in the door and the metallic sleeve for both the Blazer/Jimmy configuration and the pickups.
And yes you'll have to drill holes in the inner door to accomodate the door panel push in fasteners.
I've never used or seen the LMC panels, but I've heard the fit is fairly poor and that they shrink over time.
29od1 is offline   Reply With Quote
