Anyone familiar with Edelbrock carb vacuum ports
The Older Generation
Re: Anyone familiar with Edelbrock carb vacuum ports
I have my distributor vacuum advance on the driver side one and the passenger side one is plugged. I have my trans modulator connected to the intake behind the carb. LockDoc
Drivers side is manifold vac, passenger is called "timed" vacuum. Passenger side port only sees minimal vac until the throttle is open. Which one you use depends on how fast you want your vac timing to come in.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
If your distributor vacuum is hooked into a port threaded directly into the manifold then your fine.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
![]() Join Date: Nov 2004
Look at your distributor, the canister coming out of it should have a vacuum hose connected to it, follow that hose and make sure it is connected to something on the intake. That would mean it has full manifold vacuum, most people use the ported vacuum on the carb.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Probably an elbow fitting threaded into the intake manifold, on my Edelbrock Performer its right behind the carb.
