Trans shift shaft seal problem/replacement question
Hi All,
I have a TH350 transmission and have traced my only "current" leak of transmission fluid back to the Shif Shaft Seal on the drivers side of the transmission. To start, I did not make the score marks on the transmission near the seal (previous owner). Anyways, I removed the linkage and was able to easily remove the old seal with a sharp pick tool. I then purchased a new seal shown in photos below that has metal on one side and rubber seal on the other side. I gently slid it over the shaft, then took a socket and tapped it into place. STILL LEAKING. So my question is: Can I put some sort of liquid seal in there along with a new/or current seal (I bought 3 in case I messed the new seal up). Or does it look like a lost cause due to the damage done to the transmission housing area (from previous owner)? Also, How far back to you tap the seal in? ANY ADVISE IS APPRECIATED. Thanks in advance. |
Re: Trans shift shaft seal problem/replacement question
Could try putting alittle bit of silicone on the side where it's chewed up... And hit it in all the way seated. I have a 4 spd now but had the same problem.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
Thank you for this input, I may try and add some silcone and push it all the way in...maybe that will help. Thanks for your input.
Be careful on how much u use. I've always heard automatic's are sensitive
Watch out for your cornhole !
![]() Join Date: Jun 2003
Definitely put a dab of sealer on the outside ring of the seal to compensate for the damaged case area. It's not going to get inside the transmission.
Posted via Mobile Device |
