what brake system to change to on '66 c10
ok i would like to know from any one who has changed their brakes system over to disc which way is the best and cheapest way to go? should i keep the 6lug set up and just buy a 6 lug disc brake conversion then find power steering pump and rack from junk yard, or should i keep trying to find a early 80s donor and use whole front assembly and the buy a rear axle conversion for my rearend so to match the 5lug of the 80s...i want to keep my orignal 12 bolt rear.
live like you are dying ![]() |
Re: what brake system to change to on '66 c10
The cheapest way to go is to add a power booster and tandem master cylinder and rebuild all four drum brakes- will work good and be very reliable.
2nd choice would be donor parts . Captainfab has a list of parts posted in a forum, on how to build your own 6 lug disc brakes, using common parts store parts. I believe you still use your original A arms, too, but not sure, woould have to look for the thread about it. (Something I would look into) 3rd would be a packaged kit- it'll be complete with about everything you will need, whether you are switching to 5 lug or staying with 6. Going to 5 will involve doing something with the rear axles/drums to change them over. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
What I have done several times is just use the front suspension, steering, and brake master and prop valve from a '73-'87 donor truck. Those are plentiful and affordable.....at least in my area. Those spindles will accept the aftermarket 6 lug rotors as well. And also you can go with 6 lug front discs using all factpry parts. But that requires parts from more than one donor. This is described in the thread titled "Disc Brake Upgrade Reference Thread" It can easily be found by searching, or in the 60-66 FAQ index found at the top of the '60-'66 section page.
#4 | |
#5 | |
64-66 CHEVY JUNKIE
lasher78 if you can find a 1972 1/2ton that's being parted out that would be ideal for parts. For front breaks I used the 72 upper and lower a-arms and the complete center-link with the power steering unit attached. Everything bolted right up! You will need a power steering kit for the frame so you can bolt up your power steering correct(Capt Fab) has them.. oh yeah when I removed the 72 a-arms I just unbolted the top and bottom and removed all together.... Hope this Helps..
![]() Posted via Mobile Device
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
64-66 CHEVY JUNKIE
64-66 CHEVY JUNKIE
64-66 CHEVY JUNKIE
#10 | |
captianfab)? what about mastercylinder? that is going to change it to 5 lug right, so what did u do for rearend...want to keep stock 12 bolt Posted via Mobile Device
64-66 CHEVY JUNKIE
Yes,yes and yes, It's fairly straight forward the Hardest part is finding a 72 doner. I think the 73-87 bolt-up the same. I used all 72 parts , brake booster master cylinder and bracket...
#12 | |
#13 |
60-66 Nut
The '71-'72 control arms are no different than the '63-'70 control arms. So there's really no reason to change them for the '71-'72 arms, unless your bushings are worn out.
The '73-'87 components are easier to find, and bolt up just as easy. You can change to the '73-'87 control arms (with the better bushings IMO) if you want, or just change the ball joints in your original control arms, and then add the spindles, rotors and calipers. It really is not complicated at all. And if you want to keep your 6 lug wheels, just buy the aftermarket 6 lug rotors for the '73-'87 spindles.
#14 |
64-66 CHEVY JUNKIE
1972 Suburban Rear-End, five lug. It also bolted right in place only a couple of U-bolts to change. It was a Lil wider than the original one....
#15 | |
#16 |
64-66 CHEVY JUNKIE
No Problem Bro... Hope it helps.. Good Hunting!!!
#17 |
60-66 Nut
The '71-'72 C10 pickup, Suburban and Panel differentials will be a direct bolt into your truck. They will have the 5x5 wheel stud pattern, and are 1.5" wider that the original differential in your truck. Finding one of those around here is like finding a needle in a haystack.
#18 | |
