Old 07-10-2013, 02:48 PM   #1
1fine409
1fine409's Avatar
Taking apart hubs 87 K20?
I've worked on several 4wd front axles like this before, but on these late model manual locking hubs, the 4-lug lock nuts behind the first gear pack should be insanely tight, correct? I believe I've heard problems about them actually backing off. I know these hubs have been redone before, just wonder if the previous guy didn't tighten the hell out of them. Couldn't get them broken loose with a 1/2'' ratchet. May try a long punch and hammer tonight. Just making sure I'm not missing anything here.
1fine409 is offline   Reply With Quote
Old 07-10-2013, 06:58 PM   #2
LONGHAIR
Re: Taking apart hubs 87 K20?
The punch and hammer thing just tears up the notches, which makes them harder to deal with when going back together. I would try a longer handled breaker bar first.
I have seen these in all different styles of screwed-up. Cross-threaded, banged-up threads from beating the spindle to remove it, lock pin crushed from being mis-aligned with the lockring, etc...
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-10-2013, 09:57 PM   #3
Bigdav160
Bigdav160's Avatar
From the GM service manual:
12. Install the disc and the outer wheel bearing cone to
the spindle. Torque the inner adjusting nut to 50 ft.
lbs. (while rotating hub) to seat the bearings using
Tool J-6893 and Adapter J-23446. Back off the inner
adjusting nut and retorque to 35 ft. lbs. while the
hub is being rotated.
14. Back off the inner adjusting nut again 1/4 turn maximum.
Assemble lockwasher by turning nut to nearest
hole in lockwasher. Install outer lock nut and torque
to 50 ft. lbs. (minimum).
NOTE: Hub assembly should have .001 to .010
inch end play.
That is not insanely tight. In fact it isn't tight at all!
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
