Old 07-10-2013, 06:28 PM   #1
Idaho64GMC
Question Radio Replacement
Hey everyone, I apologize if this has been asked and covered before but a quick search of the forum didn't come up with many results for me. I have a 64 GMC pickup that I just got running and driving, It was ordered without the radio but it had a chevrolet radio put in it later on. It is AM only and doesn't work, So I was wondering if there were any inexpensive dual post radios available to put in the dash of these pickups? The posts are wider on these than most that are available that I can find, and I don't really feel like putting $200+ into a radio for a work pickup which is what the retro style radios run. Any help would be appreciated, thanks
Idaho64GMC is offline   Reply With Quote
Old 07-10-2013, 06:37 PM   #2
cortcomp
cortcomp's Avatar
Re: Radio Replacement
http://www.ebay.com/itm/1963-1964-Ra...00e688&vxp=mtr
I have one in my truck, it looks and sounds great with this speaker setup:
http://www.classicindustries.com/truck/parts/S5023.html
you can check my build thread, there are dash pictures in there somewhere with that radio in.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-10-2013, 06:42 PM   #3
Idaho64GMC
Thanks for the info cortcomp, I do like those radios, but I'm hoping to find just a basic, simple radio like they used to offer. This isn't a show pickup I just need some tunes for driving around the farm haha
Old 07-10-2013, 07:26 PM   #4
McCoyAZ
McCoyAZ's Avatar
Did you use that speaker set up as a replacement or did you buy it because there was no original speaker in the truck?
If it was because there was no speaker originally, tell me please how you mounted it?
McCoyAZ is offline   Reply With Quote
Old 07-11-2013, 12:58 AM   #5
BigDan3131
BigDan3131's Avatar
Why even bother installing a radio if your just needing it on the farm. I would just buy a cheap mini boom box...
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-11-2013, 01:21 AM   #6
Rufton
66 truck.
6x9 craig speaker fit snug w/o screws and lasted a couple decades; no rattles and didn't slip out.
Just installed 6x9 speaker from autozone w/o screws and it fits snug.
Had to remove heater controls to install.
I installed when seat was out this time.
OEM bracket for OEM under dash speaker not needed.
Speaker fits tight against dash.
Still using OEM AM radio,
Replaced radio and heater control bulbs and looks good at night.
OEM uses two different bulbs but I used same bulb in both location because they are about $6 for two bulbs.
Rufton is offline   Reply With Quote
Old 07-11-2013, 09:50 AM   #7
cortcomp
cortcomp's Avatar
Mine was in there but was deteriorated. There is a rubber "knub" about the size of a golf ball, wedge shaped, that fits over one of the brackets. As i recall, the windshield side was connected with a bracket or something, but i recall that the dash side has a bracket with that wedge shaped rubber on it, and that wedge shape matches the inside of the dash curve and just fits snug up in there. Does that make sense?
Old 07-11-2013, 10:42 AM   #8
Rufton
Make sense to me. That bracket w/ rubber knub rides well atop gas tank The bracket is designed for narrow speaker w/ tiny magnet.
Old 07-11-2013, 01:52 PM   #9
spacedebris
On the cheap, I dont think you'll have much luck except to watch ebay/CL and other sources for a used one that hopefully works. Even then, classic radios that work seem to be drawing a premium.
New options are not going to be much below $200. Cortcomp's suggestion or this
http://www.classiccarstereos.com/pro...-CHTK-230.html
are likely to be the cheapest options. at least as far as I could find.
Unless you take Bigdan3131's suggestion and go with a boom box system. http://www.yoursourcedirect.com/item...oduct%20Search
spacedebris is offline   Reply With Quote
Old 07-11-2013, 03:18 PM   #10
1963c-10
1963c-10's Avatar
I have one of the custom audio sound radios in the factory mounting location with no issues for 3 years.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-11-2013, 07:11 PM   #11
Rufton
I have a custom autosound in my car.
It is about 20 years old and still works perfect.
