Old 07-10-2013, 09:50 PM   #1
texastrendz
Fuel filter location with External pump
Hello guys and gals, Plumbing my fuel system with an External pump and wanted to know if I should put the filter before or after the fuel pump. It is a return style fuel system without the corvette style regulator. Thanks Daniel.
texastrendz is offline   Reply With Quote
Old 07-10-2013, 11:45 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Fuel filter location with External pump
Ideally you want one before and one after, but a lot of people don't run the pre-filter. You want about a 100 micron pre-filter before the pump and a regular high pressure filter after the pump. I have omitted the pre-filter in the past, but on the trucks I know I am going to be driving a lot, it's cheap insurance, since a small amount of crud can quickly ruin a fuel pump.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-11-2013, 12:07 AM   #3
texastrendz
I have currently a 40 micron filter after the pump planned, I am using all AN -6 fittings in my fuel system. I can see if they make a 100 micron filter with AN fittings, thanks Daniel.
Old 07-11-2013, 01:06 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't bother with a pre filter, just because it can be annoying finding reasonably priced fuel filters in a variety of micron sizes, AN sizes, AND FI pressure rated.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-11-2013, 01:29 AM   #5
Kim57
Kim57's Avatar
This is what I'm using for my pre-filter. You can get adapters for for the AN -6 lines.
Kim
http://www.summitracing.com/parts/sum-230118/overview/
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-11-2013, 12:28 PM   #6
Jon01
Jon01's Avatar
I have the cheap clear plastic pre-filter on mine and the C5 filter inline is mounted on the frame about 1/2 way between the pump and engine.
Haven't had an issue yet.
Definitely run a pre-filter. I found out the hard way that the inline pumps don't like junk running thru them. Cost me about $200 to fix what a $4 pre-filter could have avoided.
Jon01 is offline   Reply With Quote
Old 07-11-2013, 07:46 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm curious tho; are the low pressure fuel filters really ok for use as pre filters?
Sure its not on the pressure side, but wound't there still be some vacuum/suction pressure that might be a problem for a plastic filter?
Old 07-11-2013, 09:54 PM   #8
Jon01
Jon01's Avatar
I've done it on 3 swaps now and haven't had an issue. I was concerned on the first but had a bunch of gunk in the fuel system that I couldn't get rinsed out of the tank so a high $ filter wasn't really an option plus I was backed up on a show date so had to make it move...still running today about 3 years later.
It doesn't suck THAT hard...insert wife comment here.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Old 07-11-2013, 10:58 PM   #9
ls1nova71
ls1nova71's Avatar
I tried a regular filter as a pre-filter once and it was too restrictive. It was a metal one and not the clear plastic so there might be a difference there.
Here's what I'm running now. 100 micron, with cleanable element, and made in the USA! I don't think you'll find a more reasonable price on one it was $27 plus shipping. http://www.robbmcperformance.com/products/filters.html
Old 07-12-2013, 10:13 PM   #10
mooseknuckles
mooseknuckles's Avatar
I don't run a pre-filter either, but often thought about adding one.....my filter/reg is mounted on the outside of the frame rail under the passenger seat to keep it away from the exhaust....
mooseknuckles is offline   Reply With Quote
Old 07-15-2013, 07:27 PM   #11
c10seconds
c10seconds's Avatar
Heres how I put mine together
c10seconds is offline   Reply With Quote
Old 07-15-2013, 10:14 PM   #12
Jon01
Jon01's Avatar
At $27 and made in the USA that's easily worth the shot.
I'm having to re-do the suction side of my fuel system anyways so I decided to give one a shot.
My pump is kind of noisy, I'll report back if it quiets down at all with the new filter.
Old 07-16-2013, 11:16 AM   #13
mcbassin
Still Learning
mcbassin's Avatar
I haven't added a pre filter but I am considering going back and adding the one posted by lsnova. But here is my filter/regulator location :
mcbassin is offline   Reply With Quote
Old 07-22-2013, 11:16 PM   #14
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
That's about the exact same location as mine too.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
