Old 07-11-2013, 12:16 AM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
Question 5.3 LS Swap
Okay I have a couple of questions. First will the newer LS motors bolt up to an old style transmission such as a th350 without any problems? Can the LS have a carb conversion done to it? And last are there any oil pans made for this bodystyle truck in 4wd applications?
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 07-11-2013, 07:53 PM   #2
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: 5.3 LS Swap
I'm Know you can use a carb on an LS, you will still need an ignition system though.
Here is one thread I fond on the topic.
http://67-72chevytrucks.com/vboard/s...d.php?t=324644
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 07-11-2013, 09:09 PM   #3
Blackpony
Blackpony's Avatar
Re: 5.3 LS Swap
You will need a set of 1" setback plates for it to bolt up to the th350 and the trans stay in its factory place. Yes you can put a carb on msd offers a solution to the ignition. I am not sure about the oil pan as I am not familiar with how they are setup on the 4x4
Blackpony is offline   Reply With Quote
Old 07-12-2013, 05:44 AM   #4
bbbc10
Diggin The SquareLife
Re: 5.3 LS Swap
if I run the 1" back plates an since the trans stay in same spot could I use the stock ddriveshaft
bbbc10 is offline   Reply With Quote
Old 07-12-2013, 09:19 AM   #5
79Betty
79Betty's Avatar
Re: 5.3 LS Swap
Don't see y not
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-12-2013, 09:29 AM   #6
Jonboy
Slots go on anything!
Re: 5.3 LS Swap
I bought the Dirty Dingo adjustable mounts to be able to put the engine where I want it, to be able to use the original driveshaft. If your truck has a TH350 with a 9" tailshaft, a 700 or 4L60E will go right in place just by moving the crossmamber.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-12-2013, 12:56 PM   #7
Car'n'Guitars
Re: 5.3 LS Swap
No plans of going to a 700 or 4l60e. I just need to know if the housing will bolt to the block with no problem.
Old 07-13-2013, 02:07 AM   #8
Car'n'Guitars
Re: 5.3 LS Swap
Also can I run the motor without a any electronics if the ignition system is changed? Sorry for all the questions I'm new to LS motors used to the traditional Chevy gen 1 motors.
Old 07-13-2013, 10:06 AM   #9
wingnut78
Re: 5.3 LS Swap
Both MSD and Edelbrock make timing controllers for the LS engines so you wouldn't need the factory harness or computer. It's been a couple of years since I did my conversion on another car, but I went with the MSD 6LS controller since it was able to have timing adjusted via laptop or use the included timing pills with preset timing curves. The Edelbrock at the time only had the option of the preset pills.
With either of those controllers the factory coil packs are still used.
http://www.summitracing.com/parts/msd-6010/overview/
http://www.summitracing.com/parts/edl-7118/overview/
Another way, if you're looking to run a distributor, a conversion is made that the timing cover is replaced and a distributor is installed where the coil packs are no longer used.
http://www.jegs.com/p/GM-Performance...60437/10002/-1
wingnut78 is offline   Reply With Quote
Old 07-13-2013, 01:06 PM   #10
Car'n'Guitars
Re: 5.3 LS Swap
Thank you that is very helpful exactly what I needed. Do you have anything about changing to a carb set-up?
Old 07-13-2013, 01:07 PM   #11
Car'n'Guitars
Re: 5.3 LS Swap
What intake did you use if you went with the MSD ignition?
Old 07-13-2013, 01:42 PM   #12
Blackpony
Blackpony's Avatar
Re: 5.3 LS Swap
Yes it will fit just fine. I recently did a 4l60 swap and was able to reuse the stock ds again.
Old 07-13-2013, 05:27 PM   #13
wingnut78
Re: 5.3 LS Swap
I used the Edelbrock victor jr for LS1 because I'm running a larger cam and wanted to utilize the higher rpm abilities of this manifold. They also make performer rpm intakes as well as super victor. There are quite a few options for the LS1s now.
Old 07-13-2013, 05:32 PM   #14
bbbc10
Re: 5.3 LS Swap
what mounts did you use
Old 07-13-2013, 05:59 PM   #15
wingnut78
Re: 5.3 LS Swap
Yes the bell housing will bolt to the block with no problem. I do think you will need to enlarge or slot the holes on the flexplate though to allow the different pattern of the TH350 converter to bolt up. I'm not exactly sure how much they need to be slotted. I know it's something I've read somewhere on another forum about LS swaps.
Old 07-13-2013, 11:25 PM   #16
Car'n'Guitars
Re: 5.3 LS Swap
Okay thank you for the help, I may wait to do the LS swap on my truck on a later date, I plan on using my 305 out of my Camaro and put the LS in my Camaro before summer ends. Then also buy a LS for the truck before the end of winter. I can pick up running 5.3 LS for $440-$550 range.
