Old 07-11-2013, 01:08 AM   #1
kswindell
Under instead of over the rear end
So I see that everybody raises the rear frame rails over the rear end to get low. Why does no one ever go under? Then you always have unlimited down. Only a limit on the up.
kswindell is offline   Reply With Quote
Old 07-11-2013, 01:20 AM   #2
19666Trucker
19666Trucker's Avatar
Re: Under instead of over the rear end
That sounds like a lot of work when building bridge is easier, instead finding the right levers or trailing arms to work right
19666Trucker is offline   Reply With Quote
Old 07-11-2013, 01:26 AM   #3
kswindell
I don't really see how anything changes. Other than the route the rail takes. Without a bridge you don't have to adjust the bed other than for the housing.
Old 07-11-2013, 06:04 AM   #4
DURG
DURG's Avatar
You still need something up there or built up from the frame to mount the top of the shocks, upper spring seats, and all the structure for the bed floor mounts to, so it doesn't seem like it would be easier or lighter anyway. I used to run an under slung frame on my circle track car but you still had the rear cage tubing to mount the coilovers etc from. To me for a regular truck the over the top seems simpler.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 07-11-2013, 09:01 AM   #5
geezer#99
geezer#99's Avatar
It can be done but the scrub height gets too low. In order to have clearance for movement of the axle downward (you need about 4" from frame to axle tube) the frame bottom would be below the bottom of the wheel rim. If you're building a donk with 26" rims it might work.
Old 07-11-2013, 09:27 AM   #6
wayno
I was thinking the same thing - the travel would be such that anytime you hit a pothole or speed bump you would have some serious issues - my development has these Belgian block curbing at the street and if I couldn't air up I would be picking up pieces.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 07-11-2013, 09:41 AM   #7
concretekiller
People have done it. It's called under-slung. What happens if you're running big wheels and have a flat? Axle hits the frame before it untucked to get it off. No thank you.
concretekiller is offline   Reply With Quote
