switching to spin on oil filter help?
so im sure this thread has been made but ive done some searching and couldnt really find anything like i need. im looking to see if there is a spin on oil filter adapter that bolts to the frame. i dont want to reuse the original style that came on my 235. if not please show me some pics of what you guys have done to remove this bulky in the way filter. sorry for the bad pic below its the only one i have of this side of the motor currently. As always thanks for the help in advance i really appreciate it
Re: switching to spin on oil filter help?
Why get rid of something that works? Filters are still available. Having said that, just look for a race car remote adapter and run the supply and return lines from the block. They will be setup with a fitting to replace the spin on on the SBC/BBC blocks. Jegs currently is running free shipping.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Just curious what it is in the way of?
There are several remote filter mounting bases in this O'Reilly's link. http://www.oreillyauto.com/site/c/se...0538/C0119.oap You can find the same ones and more on Ebay or Summit, Jegs or Northern Auto parts.
To properly update the oil filtering you need to switch to a full flow filter setup. In order to do that you need to machine the block. Here is a link of the writeup that I used.
http://www.speedprint.com/deves50/oilfilterinstall.php If you are just wanting to get rid of the bulky filter then follow the same steps for the adapters/ lines and you'll be set. I used -8 earls braided nylon line and an fittings. ![]() ![]() |
