Old 07-11-2013, 02:35 PM   #1
63Ton
4wd axle vs 2wd axle
Are the axle shafts swappable between 4wd and 2wd 10 bolt truck axles?
Mark
63Ton is offline   Reply With Quote
Old 07-11-2013, 03:35 PM   #2
1774btcrew
1774btcrew's Avatar
Re: 4wd axle vs 2wd axle
They are interchangeable as long as they are from the same era.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 07-11-2013, 07:34 PM   #3
Tom
driving is in my blood
Tom's Avatar
Why do I remember something about 2wd and 4wd's being different widths? Is that only frontend maybe?
Old 07-11-2013, 07:40 PM   #4
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Yup, that's the front end, rears are the same width. Just don't forget to grab new brake drums with the correct B.P.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 07-11-2013, 08:56 PM   #5
63Ton
Thanks, now I can start looking for a 4x4 rear axle with 3:73 or 4:10.
Regards,
Mark
Old 07-14-2013, 01:02 AM   #6
sierra4x4
sierra4x4's Avatar
I've used a 2wd axle in a 4wd just swap the axle shafts and drums. The shock mounts are different the 2wd one mount the shock lower. The 4wd shock mounts are about 3 inches higher to compensate for the higher stance of the 4wd.
sierra4x4 is offline   Reply With Quote
