Old 07-11-2013, 04:45 PM   #1
BONUSCAB
Frame painting and rust removal.
The box is coming off my truck so it can get replaced. Does any one have any suggestions to clean up the rust that isn't gonna create clouds upon clouds of rusty dust? I live on an alley and i don't want to coat every ones garages in a staining coat of red dust.
The next question \is about paint. What is good? I'm not sure I wanna go through the trouble and cost to POR15 it. I'd like something cheap, that i can brush on and, that won't fall off next week.
Am I asking too much?
BONUSCAB is offline   Reply With Quote
Old 07-11-2013, 06:05 PM   #2
1981Stepside
1981Stepside's Avatar
Re: Frame painting and rust removal.
The only way I know of to avoid the red dust cloud is to either hand sand or to soak down the frame as you work. Then you only end up with a red mud puddle.
As far as paint, I would recommend tremclad. Buy the can and brush it on, not the spraybomb. I find brushing it on when its a bit cooler out allows the paint to flow a bit and forgives the brush strokes. Looks almost like powder coating when it dries.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 07-11-2013, 08:09 PM   #3
BONUSCAB
Well, I guess I understand it's gonna be dusty and I know something will need to be done to protect my lungs. But am I being paranoid that the dust is gonna settle on everything and stain rust on it?
Old 07-11-2013, 09:48 PM   #4
79Betty
79Betty's Avatar
I deal with rust dust every day. It'll wash off some things. I've been breathing it in for a year though too. It'll be ok.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-12-2013, 10:48 AM   #5
nheller76
nheller76's Avatar
Rust dust won't kill u, just make u look like u were snorting pixy sticks. U can cut down on the dust buy using a small electric sander, air tools are faster but they spit it everywhere. But in the long run the dust won't travel to far, if there us wind then your screwed but we I'm in the process of helping.a buddy do .a ground on a 55 bellaire wagon and the dust stays within 10ft of the car. And we are using air powered DA's.
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 07-12-2013, 01:45 PM   #6
BONUSCAB
I'm. not so much worried about breathing the dust, but I am paranoid about ****ing up the houses and garages around me in my alley where I will be working.
Old 07-12-2013, 03:52 PM   #7
71maligreen
wet it and wire wheel it with a drill then spray bomb with anti rust primer in black (rustoleum) works well and lasts, then go over it with a semi gloss black looks great and lasts a long time!!!
71maligreen is offline   Reply With Quote
Old 07-12-2013, 03:54 PM   #8
71maligreen
before
after
Old 07-12-2013, 04:32 PM   #9
BONUSCAB
Looks good. Mine is way, way, way, way rustier than yours. Pics to follow...
Old 07-12-2013, 11:29 PM   #10
nheller76
nheller76's Avatar
Originally Posted by 71maligreen View Post
before
after
Its fun after all the sweat and the O s#$&'s that it looks that good. I did that for mine a while back. your paint looks way better then mine though. the wire brush idea is good, I agree with wetting it down if your worried about your nabors. Dont feal like you have to get every bit of rust off though. the rust killer is a good thing, just get the loose stuff then spray it with rustoleum. use it at a primer then paint it what you want it really does work great.
Old 07-13-2013, 09:21 AM   #11
BONUSCAB
Thanks for the tips! I'm gonna hit it with a wire wheel and needle scaler, then brush on Rustoleum 7400 series paint. ( http://www.rustoleum.com/product-cat...c-alkyd-enamel ) I wish they had a semi gloss black, but flat will be fine. I have a connection at the a Sherwin Williams store, so I'm gonna go talk with him and see what he recommends. This is by no means a show truck, or fancy. Hell, it's barely nice. But I want to clean it up while I've got the room. We did some painting on the old box last night. Scrapper is coming this morning to pick it up...
Old 07-13-2013, 01:18 PM   #12
BONUSCAB
Lots of work to do! Got the bed off today. Gotta fix the frame where the abomination of a rear bumper was welded to it and ruined the frame. Gotta wire wheel and needle scale everything and mop some paint on it, run new brake lines, run new fuel lines and replace at least one fuel tank.
Old 07-13-2013, 01:32 PM   #13
hatzie
Moderator
hatzie's Avatar
Pressure Washer Hydro Blasting??
Pressure washer sandblasting - Youtube
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-13-2013, 01:52 PM   #14
BONUSCAB
That looks amazing. I'm gonna look into that further. That is some of the most useful info I've found in a long time!! THANKS!
Old 07-14-2013, 07:43 PM   #15
BONUSCAB
Got all the brackets off I could. Got the left tank out. Wire wheeled a lot of it and mopped on some Rustoleum Rusty Metal Primer on what I got cleaned. Gonna sandblast all the brackets and paint them before putting them back on. Gonna borrow a needle scaler and get in and around the spring brackets. Wasn't nearly as dusty as I thought it would be. I guess I was just being paranoid.
Old 07-14-2013, 08:12 PM   #16
79Betty
79Betty's Avatar
Isn't it amazing how much easier things are with the box off? When i took mine off i redid it all and swapped axles. Now redoing it all again lol
Old 07-14-2013, 09:21 PM   #17
BONUSCAB
I took the box off so I can replace it with one that isn't ruined. My truck was all but unusable as a pick-up with the bed that was on it. But yes, things are way, way easier.
Old 07-14-2013, 09:39 PM   #18
Sodell
Sodell's Avatar
Was it easy to get the bed bolts off. I plan on taking mine off soon. My 87, I had to cut some of them off with a torch....
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 07-14-2013, 10:01 PM   #19
BONUSCAB
Getting the bed off wasn't hard, but it wasn't easy. Torch would have made it easy. between rust, and the truck having a water tank in the bed for a long time all of the bolts had to be hacked away at with a cutoff wheel to get the bed off.
Old 07-27-2013, 06:28 PM   #20
BONUSCAB
Making progress...
Old 07-28-2013, 06:12 PM   #21
cedens
cedens's Avatar
I plan going with rhino lining on my under-carriage, and possibly the floor pans, but i'm not going for "original stock" as of right now just something that will last another 30 years, and my grandkids will think is cool
cedens is offline   Reply With Quote
Old 07-28-2013, 07:46 PM   #22
BONUSCAB
I'm not going for factory, I'm going for not rusty as sheet...
Old 08-04-2013, 10:30 PM   #23
BONUSCAB
All of that hard work... And now you can't even see it!!
Old 08-05-2013, 03:36 AM   #24
dieseldawg142
dieseldawg142's Avatar
^^ put a lift in it & show it off!
nice job, & even if people can't see it, at least you know your frame isn't turning back into base elements
dieseldawg142 is offline   Reply With Quote
