07-11-2013, 06:03 PM | #1 |
Better late than never
Help: Brake pedal going to the floor
Most of the time I have good brake pedal, but every now and then it will go straight to the floor and pumping doesn't bring the pedal up. Fluid is full and pads are ok, so is this probably a master cylinder problem? Thanks for the help.
1970 C/10 SWB Stepside |
07-11-2013, 06:19 PM | #2 |
Proprietor of Dale's Corner
Re: Help: Brake pedal going to the floor
Yes probably the master
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-11-2013, 06:22 PM | #3 |
Active Member
I also agree with master cylinder being the problem. Don't use the truck until you replace it. It's a scary feeling when you suddenly lose brakes. Been there.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
07-11-2013, 06:38 PM | #4 |
x 3 on the master cylinder .....
07-11-2013, 07:02 PM | #5 |
x4....if you are not loosing fluid, it's really the only thing that it can be.
Just replaced one on another vehicle with these same symptoms....cured it. Side note: I was able to do this without bleeding the brakes in the traditional way. I just threaded the lines into the master cylinder (after bench bleeding, of course) barely hand tight. Then I had my daughter (12 years old) push the pedal to the floor and hold it there while I tightened up the lines (tighten, loosen, tighten, loosen, tighten....to make a good seal). She released the pedal. Then I topped off the m/c, and pushed on the pedal....good and firm it was! Pushing the pedal with the lines only hand tight effectively bled that bit of air from the system. These instructions came with the new m/c. Seemed so simple, and it was. I was thinking I would have to do a complete bleed, but it wasn't necessary.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
07-11-2013, 07:05 PM | #6 |
Thanks I appreciate the confirmation!
07-11-2013, 07:07 PM | #7 |
Thanks Slik I will give that a try.
07-11-2013, 07:11 PM | #8 | |
Active Member
That bleeding technique makes sense. Wish I had known to do this before. I'm so used to doing it the old way I just don't read instructions. I guess I need to.
07-11-2013, 09:22 PM | #9 | |
Trust me, it wasn't without complaint!!
