Old 07-11-2013, 09:57 PM   #1
profe56
How to swap column, stering box, power stering on a chevy truck 56 1/2 ton?
May be, my first question was lost.
Hi guys from San Diego.
Could you give me some ideas how to upgrade a chevy 56 truck 1/2 ton with power stering?
thanks
profe56 is offline   Reply With Quote
Old 07-16-2013, 08:19 AM   #2
63 & 64 Bowties
and a few others
Re: How to swap column, stering box, power stering on a chevy truck 56 1/2 ton?
Your post wasn't lost, you just posted it in the Pre-47 forum. I moved it for ya.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 07-16-2013, 07:38 PM   #3
profe56
Thank you so much.
I found some info in Classic Performance Parts.
They have two kits: one expensive that includes stering box,power stering pump and stering column,plus some spacers and brackets.
Other less expensive that is only brackets and spacers that allow swaping 71 and newer chevy van stering box,pump and column.
Now I'm reading both info, but if one member at this forum has any ideas, are very welcome.
Old 07-16-2013, 07:44 PM   #4
OrrieG
OrrieG's Avatar
If you look up converting a Ford F-100, they use a Toyota box, mounted in the same location as stock so you do not have the problems with the drag link and tire interference. I have also heard that some mid 2000-10 Gm truck boxes might work to. Look at Denee's thread, she used one of the kits.
OrrieG is offline   Reply With Quote
Old 07-16-2013, 08:15 PM   #5
profe56
Thank you is, is chevy 56 1/2 ton.
Old 07-17-2013, 09:20 AM   #6
Russell Ashley
Russell Ashley's Avatar
I would stay away from the kit that mounts the box outside the frame in front of the axle. I have that one and don't like it. I think the other style that mounts a box in the stock location would be better, but knowing what I know now I wouldn't use either one. I'd apply the cost of those kits toward a Scott's setup.
Russell Ashley is offline   Reply With Quote
Old 07-17-2013, 11:20 AM   #7
mknittle
mknittle's Avatar
I agree with Russell the geometry on both kits are just bad.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-17-2013, 01:14 PM   #8
profe56
Thank you, that's what I want to hear, your experience and counseling is very appreciated.
Now I'd like to know were in this forum can I find the SCOOT'S SET UP.
Old 07-17-2013, 01:23 PM   #9
dubie
dubie's Avatar
http://www.scottshotrods.com/frontends.asp
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-18-2013, 06:21 PM   #10
profe56
Me too, thank you.
Old 07-18-2013, 06:43 PM   #11
profe56
Sorry: mi name is CRUZ
Old 07-18-2013, 09:18 PM   #12
mr48chev
mr48chev's Avatar
The 56 F-100 guys are saying a power steering box for an 85 Toyota 4x4 is the one to use.
My ongoing truck projects:
Old 07-18-2013, 10:10 PM   #13
roger55
roger55's Avatar
CPP just came out with a new PS box earlier this year. They call it a CPP 400 box and it mounts in the same location as the original box does just like the Toyota one does.
I have the 400 box but haven't driven the truck yet as I am in the middle of the restoration on it.
I do have it mocked up in place though.
The steering column is and Ididit column shift model.
roger55 is offline   Reply With Quote
Old 07-18-2013, 11:02 PM   #14
profe56
Thanks for the pictures.
