07-11-2013, 11:06 PM | #1 |
Vintage Air compressor relay
Got my VA unit in and loving it. Very impressed with how well it keeps up in this south Texas heat. However, I think VA might have been on a bad run of relays when they packed my kit. Originally I was having trouble keeping the compressor cycling so I called in and got some help chasing down the problem. One suggestion was to swap the heater and compressor relays. Boom. Problem solved. I've been running like that for the last 45 days (and guess who didn't order another relay to replace the original - who needs the heater here, right?) and today the second relay goes on the fritz.
Question - Does anyone who is familiar with this part know a part number or common application for the relays on this diagram? http://www.vintageair.com/Instructio...%20DIAGRAM.pdf I'd like to drive this weekend and it'll take a few days to get parts from VA. Maybe I'll carry one down to Orielly's and see if they have a suitable replacement. |
07-12-2013, 06:10 AM | #2 |
Re: Vintage Air compressor relay
The diagram shows regular bosch style relays. Very common and higher amp versions are available.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
07-12-2013, 11:47 AM | #3 |
Old member
O rielly has them on the shelf where the light bulbs are. It's the same relay I used on mine and for the head light relays.
