Old 07-12-2013, 09:32 AM   #1
andrewt2
andrewt2's Avatar
It runs!
Small victory my 5.3 swap ran for the first time tonight. I got it all together and it would not run for the life of me. After searching the forum and bugging the crap out of my tuner I finally realized it was the fuel injectors needing cleaned. Soaked the injectors over night in seaform put it back together and last night she fired first try and ran like a top. Just have a few minor details to button up on it and hopefully then will start driving the wheels off of it.
I'm running a 2003 5.3L DBW engine, 4l60E Trans, 98-02 Camaro Radiator and Cooling fans, 98-02 camaro fuel tank and pump and factory manifolds for now.
andrewt2 is offline   Reply With Quote
Old 07-12-2013, 10:36 AM   #2
RaceAGMC
RaceAGMC's Avatar
Re: It runs!
Congrats!
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 07-12-2013, 10:39 AM   #3
Indian113
Indian113's Avatar
Re: It runs!
That's a great feeling isn't it. Enjoy
Indian113 is offline   Reply With Quote
Old 07-12-2013, 01:47 PM   #4
faribran
Re: It runs!
good. congrats.... so, tell us more about the camaro gas tank and specs on mounting/plumbing it.. please.
faribran is offline   Reply With Quote
Old 07-12-2013, 04:02 PM   #5
andrewt2
andrewt2's Avatar
Re: It runs!
member ackattack did a good write up about the tank and pump in his build it does require trimming the lower frame rail but other than that it's just drilling some holes and making some straps for it to hang off of.
Old 07-12-2013, 07:30 PM   #6
yossarian19
Re: It runs!
Did you use the vacuum brake booster hose on the motor? Or plug it? Trying to find out what to use to plug mine, as I'm running HB.
Congrats on getting it going!
yossarian19 is offline   Reply With Quote
Old 07-12-2013, 09:59 PM   #7
Mr. 250r
Mr. 250r's Avatar
Re: It runs!
I could be wrong here but gm has a vacuum plug that goes in there on the back of the manifold for i guess hydro boost setups because my 6.0 i guess had hydroboost and had a plug in it and has a hydroboost pump but im using vacuum brakes so i ordered gm's vacuum piece and swapped it in
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 07-13-2013, 06:51 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: It runs!
congrats!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
