07-12-2013, 09:55 AM | #1 |
Swap Ring and Pinion or New Rear End?
When I traded my 71 GMC C20 for an 85 Chevy K20 last year, the guy told me that the PO had swapped the rear end and the gears no longer matched up with the front differential. Other than that, the truck was great and it was an awesome deal, so I made the trade.
The spid in the glovebox says 4.10 gears so I assume that is what is in the front. I'm also guessing that the rear is something like a 3.73. When I was driving in 4wd recently, my dad was following me and said he could see my rear wheels kick up on occasion which tells me they are moving a bit faster than the front. It also felt lurchy around corners, straightaway not so much. At most I went 20 mph. So - would it be best to get a new 4.10 ring and pinion to put in or go junking and find a complete axle that already has the right gears? I have heard the pros and cons from a few people I know but wanted to hear from the wizards on here before I made my decision. My current axle is a GM Corporate 14 bolt, 8 lug. |
07-12-2013, 10:22 AM | #2 |
Re: Swap Ring and Pinion or New Rear End?
With that mismatch of gear ratios, I'd be very surprised if the vehicle would move at all.
Best thing would be to pull the covers and verify what you have.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
07-12-2013, 11:19 AM | #3 |
Proprietor of Dale's Corner
X2
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-12-2013, 09:28 PM | #4 | |
If they really are different, DO NOT drive it locked in. You WILL damage "something".
As the others have stated, verify the current gearing and go from there. "Lurchy" around corners could mean that the previous owner installed some kind of traction device. Detroit Locker maybe? Yet another reason to pull the covers.....
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
