Old 07-12-2013, 10:05 AM   #1
Steve Cole
Is this spot OK for a temp sensor??
I want to put my water temp sensor here so the wiring is less visable. I don't have a place on my pre '67 Camelback heads to install this so the intake is my only option. Would this spot be any less accurate than up front next to the thermostat? Thanks!
Steve Cole is offline   Reply With Quote
Old 07-12-2013, 10:07 AM   #2
big d's red67
big d's red67's Avatar
Re: Is this spot OK for a temp sensor??
From what I've been told the best place is right by the water neck, most accurate reading.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 07-12-2013, 12:30 PM   #3
Steve Cole
Thanks. I was thinking the same thing but I had a buddy say anyone of the ports on the intake will be almost identical as far as temp readings go. Also I saw another truck that had it in the back so I started questioning this.
How much of a temp difference do you think there would be between the front port and the back port?
Old 07-12-2013, 03:46 PM   #4
hayhauler71
hayhauler71's Avatar
Mine is mounted in the rear of intake and is very accurate
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 07-12-2013, 07:58 PM   #5
Steve Cole
Thanks Hayhauler, I was hoping I could put it in the back of the intake. Funny thing is, that port doesn't even look like it could be a water jacket, it looks too thin there.
