Dude...I'm a CHICK
fan belt help?
Ok, I have forgotten the joys of changing the fan/alternator belt. AFTER you get the alternator loose, take off the valve cover, take off the fan, how in the heck do I take off the LOWER belt to get the old fan belt off? Geeze...this should have been easy right??
![]() Thanks junk
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
Member #1049
Re: fan belt help?
Jodie,
You will have to loosen up the power steering pump, remove that belt, then the fan/alternator belt will come off. |
Dude...I'm a CHICK
Re: fan belt help?
LIvrat, that's what I was thinking, is there just 2 bolts? one upper and one lower? I don't have to take the bolts all the way out do I?
#4 | |
Active Member
![]() Join Date: Jul 2007
Re: fan belt help?
Once the belt is off its pulley I pass it around the fan blades one blade at a time while rotating the fan. Hope that makes sense.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Dude...I'm a CHICK
Re: fan belt help?
Thanks! It makes sense, The fan I prolly could have worked around, easier to take off, my valve covers are too tall and blocks my alternator from moving. Ive done this before, years ago. Its gotta be my oldtimers setting in.
Member #1049
Re: fan belt help?
There are actually three bolts, well.. to nuts and one bolt. none need removing, one bolt lower front of the ps pump, one nut lower rear ps pump, one nut upper rear ps pump adjuster, after loosening those you should be able to push the ps pump inward and remove the belt.
Dude...I'm a CHICK
Re: fan belt help?
Yaay!!! We did it yall! I didn't even break a nail
![]() Group hug... ![]()
#8 | |
Active Member
Re: fan belt help?
