trans cooler lines
Ok so I just put my new engine, trans and headers in and I was hopping up and down excited until I noticed that my old stock trans cooler lines won't fit past the headers! So what have u guys done with yours?
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
Re: trans cooler lines
i just bent up new ones! took me 10 minutes, ran them right off the tranny up to the frame rail and to the cooler
1986 LWB c10 w/327 & vortec heads ![]() |
#3 | |
Steel line is best for the most part, you will have to get a flairing tool though. If you use rubber line make sure its for high pressure applications!
i got a pipe bender today and am going to try it that way, any tips?
Pipe bender is half of equation routing of the lines is another matter all together. I tried doing my own. It took a lot of back and forth and couple of scrapped tubing sections. In the end I went with pre-made set from Right Stuff Detailing Automatic Transmission Cooler Lines (Part # TTC7503). The lines are bend using CNC bender and there are no bad bends, plus fit and routing are just right.
http://www.summitracing.com/parts/rs.../c20/year/1978 //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Thats the thing I have 2 good trans cooler lines. The problem is that then get bound up trying to go around the headers. They are right wear the lines were originally.
I replaced the metal lines with stainless braided lines and an fittings.
Posted via Mobile Device |
