Old 07-12-2013, 11:52 AM   #1
Scott>72-GMC
Scott>72-GMC's Avatar
Anyone ever restore their original ac system??
Is it possible? Mine had the belt removed from the compressor so not sure what I got yet
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 07-12-2013, 12:18 PM   #2
cdowns
cdowns's Avatar
Re: Anyone ever restore their original ac system??
most all parts still readily available// i've found alot have seized compressoms or clutches that are bad// then it is just a matter of tracing wires and vaccume lines to make sure stuff works
the big deal is if it needs to b charged or not////R12 $$$$$ or convert to 134 or other ones
Old 07-12-2013, 01:00 PM   #3
kcsa75
kcsa75's Avatar
I took mine to the guy that works on my Explorer. They had to replace a switch then loaded up with compressor oil and charged with R134. The compressor is a little noisy, but it'll freeze me out of the cab. I think it cost me about $100.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 07-12-2013, 01:20 PM   #4
nightmare
nightmare's Avatar
in a system that originally had R12? that's a ticking time bomb waiting to happen.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 07-12-2013, 01:52 PM   #5
northerngmc
northerngmc's Avatar
I was in a similar situation when I bought my 68. Belt was off and the PO told me he had put the belt on and the compressor was noisy.
I looked into just having the system charged but then thought about the price difference between kind if fixing it and really fixing it. I felt that if the belt was off the compressor was probably past due. So I bought a compressor, new dryer, and a r134 conversion kit and took it to a shop. They sucked out the r12, replaced the compressor and dryer, and did a vacuum check before recharging it with R134.
Probably cost me $1000, but that was a couple of years back and it works great. Now I live in the middle of no where ( 60N 112W) and had to pay to ship parts. I would hope you would get it cheaper.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 07-12-2013, 05:44 PM   #6
MARKDTN
If the belt is off, the compressor is likely bad. I would replace the compressor, dryer and expansion valve. If you want to go to a Sanden compressor, this is a good time. I will use R12 until it is not available anymore. You will not convince me that it cannot be bought. I tried for years to sell a virgin 25lb cylinder for the $200 I paid when they quit making it (let alone the $500 everybody said I would be able to get). Finally sold it last year. That is enough to do 6 or so trucks. R12 is out there if you look. Whatever you do, use either R12 or R134. Stay away from blends IMHO.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-12-2013, 11:15 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
FWIW.....I used Freeze-12 in my '91 Celica and had no problems with it. I don't know what kind of blend it is, but I assume it is a blend.
I have the factory AC unit that I removed from my '69, and I will not be reusing it. The unit worked and was cold when I got the truck. The control unit had a bad switch and the P.O. installed a 2nd switch to engage the clutch on the compressor. I have since gotten another switch ass'y. I reckon it could be sold on the Parts pages, but shipping is gonna be a killer if you don't live close enough to pick it up.
Member Nr. 2770
Old 07-13-2013, 02:12 AM   #8
Scott>72-GMC
I think I have everything there to hook it up. I have lines disconnected now there was nothing in the system I will dig more into it when I pull the motor the po swapped this motor in that's my assumption on why the belt wasn't put back on cause someone stole the dash controls How hard is the conversion kit for r134?
Old 07-13-2013, 11:08 AM   #9
DT1
DT1's Avatar
Not wanting to cause a fire storm here but I was told (By an experienced A/C specialist) that the R134 you get today is totally compatible in older R12 systems. Use to be that the R134 and R12 oils weren't compatible but today they are. I had my stock R12 system charged with R134 (With no other modifications) over four years ago and to date no problems.
DT1 is offline   Reply With Quote
Old 07-13-2013, 11:30 AM   #10
Scott>72-GMC
I thought I heard something on this as well so ur not alone
Old 07-13-2013, 12:44 PM   #11
1972RedNeck
1972RedNeck's Avatar
I've heard that PAG and ester oils both work with 134.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-13-2013, 03:03 PM   #12
mgchevyparts
mgchevyparts's Avatar
All the time. You never know what it'll need until you dig into it. I have a friend that does AC so it's cheaper for me. He first put a small charge R12 to check and right off the bat it had a leak in the condenser, so replaced that and a couple obviously bad hoses. Then charged again and it kind of worked but the valve, maybe called PTO valve was blocked so that had to be replaced. The compressor was OK and didn't leak. Most all parts are avail, just costs money He finds R12 at good prices and the blends are fairly cheap also. Replacement cond. $250, valve about $100, R12 $40, hoses about $80, his labor about $60 beer and food.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 07-13-2013, 03:04 PM   #13
mgchevyparts
I wouldn't bother changing to R134
