Old 07-12-2013, 02:54 PM   #1
king-918
king-918's Avatar
rebuilding the Th350, what are your experience and tips
I'm building my transmission to want handle about 500hp do you have any tips or do you have any war stories or experience just curious?
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 07-12-2013, 03:04 PM   #2
king-918
king-918's Avatar
Re: rebuilding the Th350, what are your experience and tips
I forgot to mention my rebuild kit is a street fighter and my converter is a 2800stall
<----Christopher
Oklahoma
Old 07-12-2013, 05:50 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Tci kit?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-13-2013, 01:17 AM   #4
king-918
king-918's Avatar
Originally Posted by INSIDIOUS '86 View Post
Tci kit?
http://www.summitracing.com/parts/tci-328800
<----Christopher
Oklahoma
Old 07-13-2013, 02:55 AM   #5
INSIDIOUS '86
http://www.chevelles.com/forums/showthread.php?t=116768
Old 07-13-2013, 09:27 AM   #6
manimal
manimal's Avatar
clean clean clean
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-13-2013, 09:46 AM   #7
Rufton
I had a problem w/ shift kit on other trans.
Simple heli-coil project turned nightmare when drill bit broke. Don't know how to verify if bit is good quality.
Meet all factory specs.
Do air pressure function checks before mounting valve body.
Use vaseline if need to hold parts for assembly. ATF soak clutches. ATF or better assembly lube during assembly.
Double check torques w/ accurate wrench. I stripped thread following mfg torque spec.
Fill TC before assembly.
Verify TC fully seated.
Rufton is offline   Reply With Quote
