07-12-2013, 04:01 PM | #1 |
what mods have you done to your truck?
Was just wondering what mods others have done to their trucks. I have done a halogen conversion, phantom grille on the way to be installed, smoked tail lights also on the way 4 inch lift kit installed (i have before and after vids on youtube if anyone would like links just ask ill post) new tires and rims. I will post before and after pics once I get everything installed. Just thought it would be cool to talk about mods im always looking for more
Posted via Mobile Device |
07-12-2013, 04:37 PM | #2 |
Re: what mods have you done to your truck?
cowl hood, rear roll pan lots of engine mods, headlight relays, jammin stereo system, aux lights, brush guard, aluminum wheels, cb radio, lifted 3 inches and a hell of a lot more to go! including a diesel swap and a 4x4 conversion! like you've never seen it before,
and when i think of all the work ive done and it still looks like this!!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
07-12-2013, 04:58 PM | #3 |
I like that hood looks good. I have been browsing for a hood also. Summit has alot of hoods. Where did you get yours from?
07-13-2013, 03:40 AM | #4 |
good mark 2 inch
07-13-2013, 06:16 AM | #5 |
would probably be easier to list what hasn't been modified on my crew
07-13-2013, 10:10 AM | #6 |
Had this truck rigged up since last Oct. & just got the nerf bars on about a month ago.Way nicer getting into cab& stuff in the box!! 6" lift,35" tires& being vertically challenged ,this helped a lot...
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
07-14-2013, 07:48 PM | #7 |
Posted via Mobile Device I have put 4 inch lift kit billet grille (soon to be changed) and halogen lights
07-14-2013, 07:53 PM | #8 |
Side view
07-14-2013, 08:09 PM | #9 |
Changed doors, the 35's. then drove around for a while. Pulled the box off. Bought another one . Then motor blew got another one. Replaced cab n front end. Now i'm doing 4spd swap 205 going in and another complete body swap... Only 9g's later and STILL NOT DONE...
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
07-14-2013, 08:25 PM | #10 |
My truck is a 4 speed standard. I love it. Its got granny gear 1st 2nd 3rd. Its sounds so nice with 40 series flow masters when you just lay into it because the gears are so big in between shifting.
07-15-2013, 06:32 AM | #11 |
Old Heap Driver
New fenders, inner fenders, doors, hood, tailgate, interior, bumper, wheels, tires, grill, trim, paint, glass, bed wood, sound system, bolts nuts screws, cruise, 40K mile 454, new 700R, exhaust, bagged, and I'm sure a few things have been forgotten. Planning to add AC some day.
Yep, I spent a little money, but I have no truck payment, no "new car" taxes, and a vehicle I built touching every nut and bolt.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
07-15-2013, 08:55 AM | #12 |
That is a cool truck..Luv it.
07-15-2013, 02:43 PM | #13 |
How much does a paint job kike that run
07-19-2013, 07:22 PM | #14 |
07-19-2013, 07:23 PM | #15 |
New rims and tires put on ^^
07-19-2013, 07:50 PM | #16 |
^^^ nice!, looks good.
how's the new rubber clear? |
07-19-2013, 08:09 PM | #17 |
I ended up doing a 35 inch x 12.5 r17 on a 17x9 inch rim. Very surprised there is no rubbing! . I noticed my braking is weaker now though because of the larger tires im guessing. .. what are my options to improve braking?
07-20-2013, 01:49 AM | #18 |
3" spindles,large sway bars front and rear,energy suspension bushings all around,aluminum radiator and electric fans,performer intake on 350,holley double pump 650 street HP,MSD dizzy coil and 6al 2 box,rebuilt TH350 with shift kit and 3600 stall holeshot,8.5" rear end out of Impala '95 disk brakes and Magna flow mufflers soon I will build a 355 roller and 177 blower
Posted via Mobile Device Posted via Mobile Device
07-20-2013, 10:43 AM | #19 | |
if there's a big difference between then & now, prob. needing brakes, if it's just a little bit different, brakes are good. could upgrade to drilled rotors & ceramic pads or something similar |
07-20-2013, 04:48 PM | #20 |
Got me a TBI spacer!
07-20-2013, 06:56 PM | #21 |
I have a 17 inch rim now... is there such a thing as a 17 inch disc brake or something bigger than stock? Since I am running bigger rims? But I can tell my brakes are definitely struggling with the change.
07-20-2013, 09:09 PM | #22 | |
your stock braking system is plenty capable of stopping 35's, if everything is ok. i'm running 38.5's with stock braking system on my crew. i did re-do the brakes a couple yrs ago, used premium pads, rotors, drums & shoes. when we go camping we're right around 14k, never have a problem stopping |
07-20-2013, 10:25 PM | #23 |
I dropped mine 5/7, dodge 20" spares. I've swapped swapped differentials, went from a 4.11:1 to a 3.42:1 and got rid of the AM radio for a modern head unit. Next up exhaust, tbi, 5 or 6 speed and interior restore. All in no particular order.
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
07-20-2013, 10:29 PM | #24 |
I have a 6/8 drop done on mine with the lower control arms moved forward an inch to get me 7.5 degrees castor with a modern day alignment spec up front. Everything is urethane but motor mounts and outside front sway bar bushings. I have one ton swaybars front and addco 1-1/8th in the back. Drivetrain is 3:73 eaton truetrac diff with upgraded 30spline axles have a th350 with stock stall currently but Hughes internals and shift kit. Destroked 400 to 377 with a thumper cam. Mild ported 202 heads breathing from a weiand single plane high rise and a old Barry grant gold claw 750. Upgraded the interior from Scottsdale to some silverado stuff. Mainly just the pillar trim and suede headliner and leather wrapped dash. Added iroc gauges and sunpro triples in the cluster with a nos clock. Have a grip royal wheel ready to go in as well and a redwood shifter knob to accent it with my lokar floor shifter. Have some hid projectors retrofitted in as well to make night driving a breeze.
Whole truck is a step in the past with a little bit of modern day tech. Hopefully I can get my truck painted and finished up someday. Maybe.. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-21-2013, 12:02 AM | #25 |
Love the color. what color is it? sharp truck BTW. |
