07-12-2013, 11:33 PM | #1 |
What fittings to use?
What fittings would I need to hook up my air compressor and blow out my fuel lines?
Are there any valves inside those lines I need to know about? If I at least get the seat out Monday I'm going to try and clean the lines. ITTR |
07-13-2013, 12:23 AM | #2 |
Re: What fittings to use?
Start at one end of the line and look at it while moving toward the other end. If there's something like a filter or pump think and maybe remove and clean/replace.
Since the other end is open there should be no pressure buildup. Just put the blast tool on the end and press. |
07-13-2013, 12:26 AM | #3 |
I would just use a blow gun with a rubber tip. Something like this.
http://www.northerntool.com/shop/too...Fe9FMgodGF0AvQ Disconnect the lines from the carb, fuel pump, and tank sender. A good thing to do would be to buy some rubber fuel line and replace the old stuff that is on the truck.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
