07-13-2013, 06:19 PM | #1 |
swapping transmissions while swapping motors???
Well, just got some bad news , the original motor in my truck has significant damage, so I will be replacing it.
Would it be worth swapping transmissions too while im at it?? I personally am not a fan of 3 on the tree manual, and the truck came with the lowest gear ratio offered so I was thinking overdrive might make it far more practical due to the fact I have to get on the freeway to get to surrounding cities on a regular basis. How difficult is it to put an overdrive automatic in place of the stock manual tranny?? What items must be done to make it work?? I will be keeping it small block powered, so maybe I can find a used motor/trans combo Posted via Mobile Device |
07-13-2013, 09:11 PM | #2 |
Active Member
Re: swapping transmissions while swapping motors???
Since you're going to be redoing the truck, see if you can locate a friendlier rear axle like a 3.08. Along with a OD automatic like a 700R4 it would be easier on the mpg. On my 69 I removed the 250 three on the column and went with a 350/TH350 from a 77 impala and rear end from a parts truck. It helped on the highway and improved gas mileage a little.
The problem for you is finding the parts. Back in the early 80's there were still quite a few 67-72 chevy trucks in salvage yards. If you can find a parts truck that would be your best bet.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
07-13-2013, 10:51 PM | #3 |
What mods to make the new automatic transmission be shifted on the column??
Or do people usually run floor shifters after switching to automatics?? Ive never done a swap on a truck, on all my cars I went the floor shifter route. Most of those cars had bucket seats though. Might be able to obtain a 283 from a friend for really cheap. Worth getting or should I only stick with a 350 ?? truck is mainly gonna be a cruiser, not trying to make it a performance vehicle Posted via Mobile Device |
07-13-2013, 11:29 PM | #4 |
If you can afford it, Buy a brand new GM Good Wrench stock replacement crate motor and find a good used 700R4. The cross member and shifter linkage are going to cause you the most problem, but not major. Most people use a floor shifter because the standard shift column does not have the Park/reverse detents.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
07-14-2013, 12:53 AM | #5 |
I will say, I purchased a GM crate motor for my 1969 camaro and never had one issue.
Probably the safest route to go Posted via Mobile Device |
