Brake drag
I've got this CPP brake kit that we finally bled the entire system out on today. I am finding that the front pads drag a little to much. Is this common? Am I just going to have to drive it and wear them down or should I be taking some course sand paper to them and knocking them down a bit?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Apr 2009
Re: Brake drag
Can you turn them by hand? I used to have a tough time with front pads on a 78 gmc. Only one brand would fit right and even then without backing plates. What kind of brake calipers does the cpp kit use (obviously gm)? Maybe they cheaped out on the pads? As long as they aren't so tight theyll heat up and warp the rotors i wouldn't sweat it to much, other than make the shakedown run really short.
If you cant turn them at all i would sand them or try different pads. Posted via Mobile Device |
![]() Join Date: Jul 2010
Re: Brake drag
I have the same problem. Subscribed.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
Re: Brake drag
It seems I read quite a bit of not so good things where CPP is mentioned.
Re: Brake drag
Just general observations, no direct experience on CPP stuff...
Disk brakes drag by design. Crack a bleeder screw to see if the system is applying pressure with no foot on the pedal. It can happen. A dick brake wheel/rotor, will probably not turn 360* when spun by hand. |
Re: Brake drag
I'd say that Franken nailed it. disk brakes always have a bit of drag as that is how they are set up to work. With no springs to pull the pads off the rotor they drag on the rotor.
If you find that you have pressure at the caliper when none is applied you might have the wrong residual vales or a drum brake master cylinder with a residual valve built in behind the seat where the brake line screws in.
Re: Brake drag
One more thing to look for is where the m/c and booster are bolted together.. if the rod in the booster is to long it will put pressure on the m/c and cause the brakes to drag. It doesn't take much to cause this.. the rod in the booster is just a screw with a locking nut. I think CCP sells a tool to set this but i've made one..
http://67-72chevytrucks.com/vboard/s...d.php?t=475162 |
Re: Brake drag
Everything spins by hand, but not a full 360. Then you apply the brakes and she stops in a millisecond, so everything is working the way it should. I thought I should be able to spin the rotors a lot more but by the sounds if it, this is normal. That's good news because now, all the brakes are done. Thanks the input eh
Re: Brake drag
I run front disc brakes w/o residual pressure valve and like it.
Stops great, minimal drag and easy to gravity bleed. |
Re: Brake drag
I think you have about right Dubie, As long as you don't smell hot brakes when you haven't been using the brakes that much you are good. If you drive it ten miles down the highway and coast to a gentle stop with gently applied brakes and you smell hot brakes you have a problem but if they aren't smelling hot like they have been dragging excessively there isn't a problem. Braking at the last second to dive into stops will cause any brakes to be hot though.
#11 | |
Re: Brake drag
i had set up my brakes with the cab on, then removed it for body work between frame and body work, when i placed the cab it was depressing the brake pedal just a bit i was able to grind an eighth of an inch off the bolt diameter to eliminate the drag
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
