Fuel line routing?
Would like to see how you guys routed fuel lines from the motor down to the frame. I want to keep everything tied to the frame and not the body if possible. But any and all photos would help, Thanks Daniel
Re: Fuel line routing?
Here's what I did.
Kim |
Truck and auto performance nut
pretty much how mines run...I used all s.s. flex hose tho. Runs down the back of the motor and across the trans to the frame rail, and hugs the frame rail all the way back to Vette reg/filter, pump, prefilter and tank.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
meowMEOWmeowMEOW
I brought mine up and over, and met it with hard line run up from the frame. It doesn't anchor to the body.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
My truck is equipped with a Porterbuilt Dropmember. The motor is raised up a bit and my manifolds are angled high and sit pretty high on the frame rail. Wonder if anyone with a dropmember has picks. Gonna set the cab back on this week, will see what kinda room I got.
Still Learning
same here too...mine run to the outside of the frame to the reg/filter under the pass seat area.....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Not trying to hijack the thread, but does anyone have the part numbers for the fittings used to make the lines you guys used off of the fuel rails?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
hope this helps.....
That is exactly what I need. Thank you.
meowMEOWmeowMEOW
I have an extra set of the Russel EFI push connect fittings; but keep in mind that many have the OLD design, which uses a regular plastic center clip. These CAN and HAVE come off before under rail pressure. I had a return line fitting come off and pump fuel onto hot headers.
YOU NEED TO USE 644110 or 644120, these are the NEW design parts for 3/8 and 5/16 push on fuel fitting to -6 AN. Some have used the old style for a long time, but there has been more than 1 car lost to a fire caused by the fittings. http://www.summitracing.com/parts/rus-644120/overview/ http://www.summitracing.com/parts/rus-644110/overview/ If you want the old style, you can have my set for the cost of shipping....but frankly thats at your own risk.
#13 | |
Pretty cheap insurance for a safe connection. Kim |
#14 |
![]() Join Date: May 2013
Lot of great info in this thread. Thanks
Posted via Mobile Device |
#15 |
I need to update to those....tho I do have the fittings tension relieved/tie wrapped down in the hopes that it won't move until I do change it.
#16 | |
#17 |
![]() Join Date: Apr 2005
Good info guys!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
