Front driverside directional won't work..
For the most part I got my running lights, brake lights head lights,brights, cab roof lights and directionals working except my front driverside directional, the light works fine as far as the parking light goes just won't friggin blink!!! I replaced every fuse in the box and bought one of those stupid "heavy duty" $11.00 relays but still no blinkity blink blink... any suggestions or trouble shootings tips would be most appreciated....]
68 GMC 2500 stepside LWB 250CI |
Cruzin
Re: Front driverside directional won't work..
Did you try the bulb? double filament bulbs can work as one but not the other
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Yeppers... when I bought the truck I replaced both directional bulbs from the same package so the passenger side directional bulb that works came out of the same package as the drivers side one.. can't figure out why the light is getting power when the running lights are on and there seems to be no drain or normal signs of a short on the other lights but no flash... just a little more info.. both directional lights in the cab work as well as the driverside rear one just not the driver the front.. I also recently changed the cam on the turn signal switch b/c that was the reason the passenger side would not work but that one stupid light won't flash!!!!!!!
Old member
First things first. Take the passenger side bulb out and put it in the drivers side. if it works then it's the bulb if it doesn't check the ground for the side marker light housing should be a ground screw right behind the housing to sheetmetal.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
Second this^^^.
Follow the trouble-shooting protocol of testing with "known good" parts.....and as-always with electrical stuff, check the grounds.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#6 | |
