07-14-2013, 01:27 AM | #1 |
compressor malfunctioning
I'm having a bit of an issue i purchased a compressor used locally and it seemed like a great deal but now its starting to act up. When i go to start it from 0 pressure, it builds up pressure to about 125 psi but if there is any sort of pressure in the tank the thing just hums and the pops the built in breaker. what could be causing this its a central pneumatic 21 gallon model #47065. any advice would be appreciated.
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713 Member of tailgate association of manitoba |
07-14-2013, 09:29 AM | #2 |
Re: compressor malfunctioning
its cheap and wore out? they sell those at harbor fireght all day for 150 buxs
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-14-2013, 11:17 AM | #3 |
motor is not strong enough to start under load. what breaker is it tripping, panel breaker or one on motor. might be time for an upgrade
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
07-14-2013, 11:39 AM | #4 |
One on the motor I did some research a guy replaced his unloader valve then worked great.
07-15-2013, 01:46 AM | #5 |
Hand Crafted C-10
Keep us posted on this.
Nice to see it might have a fix.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
07-15-2013, 11:54 AM | #6 |
Yep, there is an "unloader" valve. That is the short hiss you hear when the compressor reaches cutoff. The unloader drops the pressure from the head to the tank's check valve. If your check valve is malfunctioning, the compressor will continue to his until restart or empty if you turn the power off.
The pressure controller spring cuts the power contacts and a little tang pushes an extra long shrader valve dropping the head pressure to zero so at startup, there is no load. This is a standard problem with used compressors being "rigged" to not leak. Like mine was. Your check valve is inside the can. The pressure pipe from the compressor head connets to a brass (most likely) nut at the tank. that is not a bung or flange but a check valve. It unscrews from a bung and is about 1-1/2" to 3" for big units.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
07-15-2013, 01:45 PM | #7 |
i took some pictures not too sure if this will help.
07-15-2013, 07:32 PM | #8 |
Hollister Road Co.
I would try the unloader first. It sounds like the compressor is under pressure and the motor isn't strong enough to spin it. You should hear some air release when the compressor stops, thats the unloader working. If you don't hear it change it.
