Old 07-14-2013, 10:35 AM   #1
scott-wisc
scott-wisc's Avatar
what converts from 73-87?
I'm thinking about buying a 1973 1/2 ton 2wd for the motor and misc. parts. Does anyone know if the headers will fit my 72. how about the rear axle width difference if any. How 'bout motor mounts?
scott-wisc is offline   Reply With Quote
Old 07-14-2013, 01:04 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: what converts from 73-87?
I believe the headers will interchange/fit, thru 1987 (square body). The rear end in the '73 to '75's is supposed to be the same width as the '70-72's. 1960-69 rear ends are about an inch narrower.
However, 1973-up rear ends are leaf-sprung, not coil sprung. If your '72 is a leaf spring rear, probably no issues.
Member Nr. 2770
Old 07-14-2013, 01:44 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You can also swap the front disc but since you already have them,you could recoup some cost by selling them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-14-2013, 03:45 PM   #4
nlped
nlped's Avatar
I put a '76 12 bolt rearend under my '70 2wd gmc. I had to cut off the leaf spring perches and weld on a set of trailing arm perches and adjustable panhard bar that I got from CPP. The width was actually about 3/4" wider than my stock rearend ( I had the wider rear in mine). If fit really well and my Boss 338's fit like a glove.
I also used the front upper & lower control arms, steering pieces/parts, spindles, and swaybar. I also used the master cylinder.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-15-2013, 09:22 PM   #5
scott-wisc
scott-wisc's Avatar
I went to look at the doner truck and it wasn't worth half of what they were asking. Way to cobbled up. When I came home and saw my truck in the driveway, it looked mint after seeing what a hack job some people are capable of. I'm really happy she's still a virgin other than a floor shifter conversion.
Back to the drawing board.
