Old 07-14-2013, 02:24 PM   #1
tylervalo
89-91 front end harness
I've got an 83 cab and the PO put a 89' front end on it, how do I need to PROPERLY wire up the lights? Would it be best to cut the front harness from another 89'-91' or can it be done with my current harness?
tylervalo is offline   Reply With Quote
Old 07-14-2013, 06:34 PM   #2
hrc200x
Re: 89-91 front end harness
Does the current front clip have wiring in it running to the firewall? If so is that wiring from '89-91 or '83? I'm a big fan of not cutting wires whenever possible. I have had to unpin the wires going to the cab at the backside of the fuse pannel and move them to a different spot that had the correct power going to it, this wasn't because of a newer front clip but for somthing else that wasn't working.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
