Old 07-14-2013, 11:59 PM   #1
In The Ten Ring
The seat is out!!!!
We got the seat out today. A friend as able to come over and we did it. Fairly easy to move the truck over with the single wheeled hydraulic jack. Realy surprised how easily the seat came out. Just 8 bolts.
Now the real challenge begins: the fuel tank.
Can anyone tell me where all these lines go? There are two that come out of the passenger side and go into rubber tubing and two go into the floor of the cab. What are all these and what are they for?
ITTR
In The Ten Ring is offline   Reply With Quote
Old 07-15-2013, 10:08 AM   #2
Sammy
Re: The seat is out!!!!
Some have two lines through the floor. One is supply to the carb the other is a vent line I believe to a charcoal canister located in the engine compartment..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-15-2013, 12:48 PM   #3
In The Ten Ring
Well that would explain it!
do I need to blow out the rubber lines too, the ones that exit out the top of the passenger side of the tank? *I assume those are some sort of "vacuum line"?
Do I need to blow out this charcoal filter also/replace it?
