Old 07-15-2013, 07:18 PM   #1
sixTsix
transmission questions
ok fella's
here is a few questions for you ...that I should've asked a while back ...but now for some reason are not clear in my head lol..
anyhow, ive been thinking of dropping in a 5 speed in my ol bucket ...so I can have overdrive while on the freeway and what not.
now heres where it begins ...I happened to score a 5 speed out of a 88-91 chevy v8 truck... for some reason I could've swore I read somewhere , sometime that these trans will bolt right and go right in. but for some reason im thinking I might be wrong here so my questions are, will this thing bolt right to my motor which is a 75-78 chevy 350? will I be able to use the manual clutch out of my 4 speed, that currently resides in my ride? will my drive shaft have to be cut down and rebalanced? any other modifications I should be aware of before going at it?
any suggestions or help will be greatly apreciated
sixTsix is offline   Reply With Quote
Old 07-15-2013, 10:22 PM   #2
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: transmission questions
Hey sixTsix yes it will bolt to ur 350 Engine, I'm not 100% sure about the manual clutch but I would go with the hydro.clutch.. I'm sure some one else will chime in on this...
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 07-15-2013, 11:49 PM   #3
kerber63
kerber63's Avatar
If the 5 speed you're looking at is a T5:
It will mount to your 4 speed bellhousing.
Your manual clutch linkage will work, but you'll need to get a new clutch - the T5 will have a different input shaft spline count.
You will need to shorten your drive shaft.
You'll need to move (and possibly modify) your e-brake crossmember.
If the shifter is located on the tailstock (probably not since it's coming out of a pickup - s10?) you'll have to cut a new hole in the floor.
You're speedo might not be completely accurate.
I hope someone will jump in and correct anything I've gotten wrong.
I had one behind a 350 in my '63 and it was a blast.
kerber63 is offline   Reply With Quote
Old 07-16-2013, 01:21 AM   #4
mikie 1954
Need more info , is it a nv4500 , 3500 or a t5 like Kerber63 said?
mikie 1954 is offline   Reply With Quote
Old 07-16-2013, 09:28 AM   #5
Ta2Don
Ta2Don's Avatar
Out of the 88-91 full-size truck it should be the 3500. I'm dropping one of these in my 65 short stepper. My truck had a 350/TH350 combo and the driveshaft is now 3" too short. I'm going with the Hydro Clutch set-up. Member TR65 here has a great write-up on the Hydro clutch install.
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 07-16-2013, 10:03 AM   #6
1963c-10
1963c-10's Avatar
Novak has several hydraulic clutch conversions. Here is the one I'm working on for my big block build
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-16-2013, 11:10 PM   #7
sixTsix
sounds like its going to be a interesting swap to say the least.
im not sure as to which model it is ..but it did come out of a 88-91 fullsize...
I will have to research once I get a chance ...have been busy at work and not getting home till dark .
as far as the cross member, it isn't stock anyhow ...its more like something someone threw under it to make it drivable ..and after a few looks at it ...im not sure its even 100% safe at the moment ..all though it does drive without a hitch.
speedo don't work as it is ...so that's not a problem ...
I appreciate the input fella's ...I don't know exactly when im going to be doing the swap ..hell to be honest I was happy to get this one ...best part about it ..it was free ...cant be free with a stick. I do plan on going through it I was told it was out of a running driving truck ...but im one of those types of guys ...I don't trust anything till my hands been through it ..or have seen with my own two eyes. I have ran thru some of the gears and seems to shift ok ..but again ..I haven't even really had a chance to look at it yet ...it was brought to me in the dark ...and I haven't been home before dark since I got it ,...so I guess you could say im in the dark about this at the moment ...lol ..
as soon as I get a chance to give it a beter look I hit the thread back up and let you guys know what I can find out ...
Old 07-17-2013, 12:43 AM   #8
Captainfab
60-66 Nut
From what I understand, the NV3500's are quite difficult to rebuild. They require a special fixture, and most trans guys around here won't touch one.
