Old 07-16-2013, 08:49 AM   #1
Blue Heeler
Blue Heeler's Avatar
Has anyone done a T-56 6spd swap?
I bought a t-56 with all the parts and even pulled the motor. don't think the motor is any good because the guy hit a pole and smashed it pretty darn good. anyways trying to pick some heads on info and pictures if anyone has done the swap. thanks
Blue Heeler is offline   Reply With Quote
Old 07-16-2013, 09:31 AM   #2
billd5string
billd5string's Avatar
Re: Has anyone done a T-56 6spd swap?
I'd like to find out about a T56 swap as well. I'm pretty sure the clutch needs to be hydraulic and that it uses a unique bellhousing and I think a different clutch and flywheel as well. I'd like to see what's been done as well.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 07-16-2013, 09:40 AM   #3
LT1 Burb
LT1 Burb's Avatar
A buddy of mine did one in a 72, you have to use a hydraulic clutch but other than that it is straightforward. Just remember though that it is a toploader and the shifter is right at the bench seat.
LT1 Burb is offline   Reply With Quote
Old 07-16-2013, 10:44 AM   #4
theastronaut
theastronaut's Avatar
MalibuKasey just did a T56 swap behind a small block using a LT1 T56. The LT1 T56 belhousing will bolt straight up to a small block or inline 6. I believe a conversion flywheel for a two piece main seal was needed to use the LT1 clutch/pressure plate. It does use a hydraulic system, not the old style mechanical linkage. He also moved the shifter up to the inspection port using a Keisler relacation kit to clear the bench seat. I'm not sure what all is involved with using a LS style T56, the input shaft is a different length and the bellhousing won't work.
TR65 has a great write up on the shifter relocation:
http://67-72chevytrucks.com/vboard/s...d.php?t=300892
MalibuKasey's relocated shifter:
theastronaut is offline   Reply With Quote
Old 07-16-2013, 09:16 PM   #5
TR65
TR65's Avatar
Here is the way I did the hydraulic clutch.
Good luck,
TR
http://67-72chevytrucks.com/vboard/s...d.php?t=300087
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-17-2013, 12:35 AM   #6
Captainfab
60-66 Nut
If you don't already have power brakes, I sell a power brake/hydraulic clutch conversion bracket for the '63-'66 trucks. It is basically the same as what I sell for the '60-'62's.
