Old 07-16-2013, 04:10 PM   #1
TheBlueBomber
TheBlueBomber's Avatar
Need Info 1979 k10 Th350/NP203 to SM465/NP205 swap
Hi everybody, I'm trying to swap over my 350/TH350/NP203 set up eventually to a ???/SM465/NP205. Motor wise I'm thinking 454 but for now leaving it a 350.
So I've got a question or two. I recently bought a '79 k10 with a 350/Th350/NP203 setup. The truck has been converted to manual locking hubs with the 203. I want to make it into a SM465 backed by a NP205. What year transmission do I want to look at getting? I think in 86 the tranny switched to a hydraulic clutch? Do I want the hydraulic clutch setup? How hard is the pedal assembly to set up? Any information/pics or build threads will be appreciated. Thanks in advance.
TheBlueBomber is offline   Reply With Quote
Old 07-16-2013, 04:23 PM   #2
manimal
manimal's Avatar
Re: Need Info 1979 k10 Th350/NP203 to SM465/NP205 swap
If you plan on wheelin it, a hydraulic clutch is the way to go-----no linkage to fall out during flex. As far as pedal assembly goes, you will need the set up and bolt it in. You will have to drill the holes in the firewall for the mounting studs and the center of the clutch master.
As for which trans/t-case...I think the fixed yoke set up would be the best for the t-case. I need to go back over some notes I have about the trans.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-16-2013, 04:28 PM   #3
k5chevy07
Here's a few pics of when I did the swap. I went to the you-pull-it yard and found an 86 chevy with the sm465. Took everything from the transmission to the pedals to the hydro setup and even the clutch and flywheel for 150 bucks!! (All factory in 86) The swap was pretty strait forward.
I can answer any questions you may have.
k5chevy07 is offline   Reply With Quote
Old 07-16-2013, 04:34 PM   #4
TheBlueBomber
Awesome. I found an '86 on craigslist thats being parted out and is all there. im going to try and grab it all when I get down there. Where did you mount hydraulic stuff at? Factory locations for the 86?
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
Old 07-16-2013, 04:47 PM   #5
k5chevy07
On my 86 k5 there were provisions (small dimples) in the firewall where the holes needed to be drilled. You will need a hole saw to drill the ~1.5" hole for the master cylinder. I'm not sure if earlier models have these provisions tho. Once you remove your brake pedal setup you should be able to see them clearly.
Old 07-16-2013, 05:47 PM   #6
79Betty
79Betty's Avatar
If you can't get that 86 abd gottta piece it together be warned, it's pricy. Manual is easier, and cheaper. It depends on what you're using the truck for. My swap is manual. Ehy? It's a pullin truck. It will tow my sled truck. My other 4x4... Different story.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-16-2013, 07:59 PM   #7
TheBlueBomber
The truck is going to be used for light wheeling and around town. I love driving manual transmission's especially if it's in an older vehicle. Even though I wont be tearing the crap out of it, I would like to have the option to at a moments notice. I don't always wheel, but when I do, I go hard.
Austin
Old 07-17-2013, 12:49 AM   #8
manimal
manimal's Avatar
Then source all the parts to do a hydraulic set up and be done with it.
-Lance
Old 07-17-2013, 09:43 AM   #9
TheBlueBomber
Okay. The guy is asking 500 for everything. Is that a good deal?
Austin
Old 07-17-2013, 11:01 AM   #10
79Betty
79Betty's Avatar
If he included the shafts yea. I gave 400 for mine but hydraulic is always more "desireable"
Old 07-17-2013, 11:29 AM   #11
TheBlueBomber
That's with the shafts, tcase, tranny, hydro stuff, and pedal assembly
Austin
Old 07-17-2013, 12:40 PM   #12
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
That is a really good deal. Just make sure everything is included, especially the hyd. fluid reservoir which is hard to find. Also make sure to check the bell housing for cracks as the OEM casting are rather thin, and I have seen several with cracks, and or repairs.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
