Old 07-16-2013, 04:16 PM   #1
jsdoyle
jsdoyle's Avatar
350 Transmission shifting strong
I recently replaced the coolant lines for the transmission. Previous owner used the wrong type of line and they started leaking real bad.
I got that fixed. No leaks now and the truck is running real good. (knock,knock).
So good that now if I accelerate from a stop and push on it pretty good the tires will chirp going into second and even a light chirp into third.
It's shifting real smooth if I pull away normally and even when I push it hard its not a real hard shift.
Goes into first nice and easy from park. I'm wondering if this is normal from a 350 SB / 350 turbo combo?
Fluid levels look good too.
65 Chevy C10 Fleetside
jsdoyle is offline   Reply With Quote
Old 07-16-2013, 04:36 PM   #2
'65 chevy lover
Re: 350 Transmission shifting strong
Sounds like you might have a shift kit in it.
'65 chevy lover is offline   Reply With Quote
Old 07-17-2013, 10:31 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Great to hear! Yes, transmission fluid leaks will affect line pressure and reduce transmission longevity.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-17-2013, 10:39 AM   #4
jsdoyle
jsdoyle's Avatar
Not sure about the shift kit.
Keep on Truckin!
