Old 07-16-2013, 05:00 PM   #1
daveo68
daveo68's Avatar
Hei and tach problem
I've searched on here and still can't find a solution.Done the tach conversion about 4 years ago no problem with tach. Had a 700r4 installed about 2 months ago and redone my gauges, now tach won't work.Will not move when I turn switch on everything else seems to work fine. Rechecked all the wiring,found nothing,pulled dash back out all looks fine.
Could it be:
1. Bad tach
2 Bad circuit board
3. Bad distributor cap
Also have Painless wiring harness installed last year and tach worked fine.
Will appreciate any and all help.
Thanks,
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 07-17-2013, 03:30 PM   #2
daveo68
daveo68's Avatar
Re: Hei and tach problem
Any ideas?
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 07-17-2013, 04:21 PM   #3
Lee H
Lee H's Avatar
I would say lose connection or the tach has just failed. Could be coincidence or due to disassembly and reassembly.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-25-2013, 01:12 AM   #4
daveo68
daveo68's Avatar
ttt
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 08-25-2013, 01:57 AM   #5
leddzepp
Moderator
leddzepp's Avatar
I agree with lee. Have you tried running a separate ground wire to the tach itself? The tach is independent of the the circuit board also. Did it just quit one day while you were driving?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 08-25-2013, 02:36 AM   #6
BruthaMan
US Army Veteran
BruthaMan's Avatar
Might pick up cheap aftermarket tach to test your wiring with. Splice into the tach wire going to the current tach, then take the temp tach and wire off the distributor lead. May give you an idea if it's a tach issue or a wiring issue.
BruthaMan is offline   Reply With Quote
Old 08-26-2013, 11:47 AM   #7
daveo68
daveo68's Avatar
I tried anothef tach seems like i'm not getting power from the cap. Going to check that out later today. Have Painless Wiring harness installed,have not found any wiring issues yet.
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
