HEADER WRAP? Pros & Cons
Got a question for you all. Header wrap has anyone ever had it catch on fire. Mine did today I was ale to blow it out, but now I'm concerned. I've run my truck a good bite with no problems. but today when I shut it off it sounded like it was trying to backfire before the engine stop running. I had the hood rised and when I looked down I saw the header wrap near the oil filter on fire. Anyway just wanted to see if anyone else has had any bad experience with it themselves. Thanks
Re: HEADER WRAP? Pros & Cons
I've had a 350 and a 454 with wrapped headers, never had any issues. I am completely Pro for header wrap - it looks awesome and does a great job keeping the heat where it's supposed to be.
Posted via Mobile Device |
I header wrapped mine and I think as long as you seal it with the high temp silicon spray so the flammables don't absorb into the wrap you will be good. At least that is what I am banking on. First fire up tomorrow.
"You can have it Fast, Safe or Cheap. Pick any two" "If you're gonna be dumb, you better be tough" 1965 C10: http://67-72chevytrucks.com/vboard/s...=1#post6114617 ![]() 1971 Baja: http://www.thesamba.com/vw/forum/viewtopic.php?t=459552 |
Moderator
![]() Join Date: Dec 2012
The main problem with header wrap on street vehicles is that it causes pipes to rust out.
#5 | |
x2 on that one.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
![]() Join Date: May 2009
X3 looks to be allot of pro & con on this subject here is a link..Vernski
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=477864 |
![]() Join Date: Jun 2006
They rust out from the moisture in the air plus any puddles you hit or car wash you go thru. I would only use them in a drag racing app.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
Almost all header manufacturers will void any warranty if their headers are wrapped.
The most common mistake made is most do not install it correctly.. I agree that the wrap should be used for racing applications only. |
