07-16-2013, 09:42 PM | #1 |
5.3L running original radiator. Will it work?
I was wondering if my original, leak free radiator will work with my engine swap? I have soon new stuff to mount to it!
A place for everything, everything in its place. Check out my build thread! http://67-72chevytrucks.com/vboard/s...43#post6129043 |
07-16-2013, 10:45 PM | #2 |
Re: 5.3L running original radiator. Will it work?
I am using my stock 4 core in my 72 Jimmy for a few years now with zero problems. I am also only using a clutch fan.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-17-2013, 12:09 AM | #3 |
The Older Generation
It depends on which radiator you have. There are two core, three core, and four core Radiators. LockDoc
07-17-2013, 12:13 AM | #4 | ||
"I ain't nobody, dork."
Even if it is leak free... doesn't mean it is free flowing. 40 year old original radiators can hold a lot of crud over the years. You might wanna take it to a shop and have it rodded out, or maybe even a recore.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-17-2013, 01:40 AM | #5 |
how can i tell how many cores it has? thanks for the responses!
07-17-2013, 07:38 AM | #6 |
Look at it from the back side where it joins the tank and count the rows forward. You will see obvious rows of tubes.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-17-2013, 09:17 AM | #7 |
the boat guy
I ran mine on a 2 core for years without any issues.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
07-17-2013, 09:25 AM | #8 |
I think you will be fine , these ls engines seem to run cool , i hooked my steam line to the heater lines
im useing my stock radiator , still in build mode should be in run mode in a week or 2 |
07-17-2013, 11:55 AM | #9 | |
LockDoc
07-17-2013, 09:50 PM | #10 |
Thanks guys I'm going to check tomorrow. I figure it's a two core because my truck originally came with an inline six
07-17-2013, 10:25 PM | #11 |
If it's a 6 truck it probably has the 2 row narrow core unit.
Either way, if it keeps the 6 cool you'll be fine. LS motors run very cool. |
07-17-2013, 11:34 PM | #12 |
I just installed a lq9 6 litre in my 1968 c10. I thought I would try the stock two core rad. I also am using Evans waterless coolant. I have a about 1000 km on it and no problems so far.
Posted via Mobile Device |
