Old 07-16-2013, 10:51 PM   #1
Mieser3
Mieser3's Avatar
Problem With Testing My Air Ride System
I finally got everything hooked up on my Accuair e-Level kit last night and was hoping to test everything out. My truck project doesn't currently have any wiring in it. I connected everything per Accuair's instructions and I am using their power kit to the battery as well. When I hooked up the cable to my battery my compressors (I have dual compressors) run for about 2 seconds and then shut off. I have the battery on a charger as well. Is the battery I'm using not powerful enough to run the compressors? Just not sure why the compressors run for a couple seconds and then shut off and never start back up?
Jay
1956 Chevy 210 Sedan
1970 Camaro Z-28/RS
1970 Chevelle SS 396 (numbers matching L34 car)
1971 Chevy SWB Fleetside with 1967 front clip - in progress
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156
Mieser3 is offline   Reply With Quote
Old 07-16-2013, 11:04 PM   #2
Pro Performance
Pro Performance's Avatar
Re: Problem With Testing My Air Ride System
I believe the ECM will shut off the compressors if it detects low voltage. This is a safeguard to protect the compressors from draining the battery if a leak occurs. How many volts is coming from the battery and feeding the system? It should be a continuous 13.8V. I know you said it was on a charger, but I would check that first and go from there. Let us know what your findings are.
Pro Performance is offline   Reply With Quote
Old 07-17-2013, 02:49 PM   #3
Mieser3
Mieser3's Avatar
Thanks. I'll check the voltage at the battery when I get home tonight. Do I need to have the orange 12V switched wire connected to the battery to test the system?
Jay
1970 Camaro Z-28/RS
Old 07-17-2013, 03:38 PM   #4
Hart_Rod
Hart_Rod's Avatar
Originally Posted by pro performance View Post
i believe the ecm will shut off the compressors if it detects low voltage. This is a safeguard to protect the compressors from draining the battery if a leak occurs. How many volts is coming from the battery and feeding the system? It should be a continuous 13.8v. I know you said it was on a charger, but i would check that first and go from there. Let us know what your findings are.
posted via mobile device
bingo!
Hart_Rod is offline   Reply With Quote
Old 07-17-2013, 06:47 PM   #5
Pro Performance
Yes, that is supposed to go to a keyed power source, but in your situation for testing purposes, you can touch it to the battery to power.
Old 07-18-2013, 05:52 PM   #6
Mieser3
Mieser3's Avatar
I think not having the orange wire connected to the battery was my issue. Connected it and everything seems to be working perfect now. Thanks for responses.
Jay
1970 Camaro Z-28/RS
Old 07-20-2013, 10:52 AM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
We need a video of the system cycling just to be sure....
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-20-2013, 11:04 AM   #8
Mieser3
Mieser3's Avatar
There's a short video on my build thread.
Jay
1970 Camaro Z-28/RS
