07-16-2013, 11:20 PM | #1 |
Dog House removal on a 78 SWB
I am starting a tare down on my 78, and are there any tricks to remove the sheet metal in as few pieces as possible.
Do I need to remove the front bumper?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-17-2013, 12:09 AM | #2 |
Re: Dog House removal on a 78 SWB
This is how I usually do it,others might be different.Pull the bumper,makes it easier to get at the rad support mounting bolts,pull rad,& hood.I pull the whole front clip as one piece,there are 2 bolts on upper fender at rear.These are visible when door is opened,there are 2 more inside wheel well & one at rear of fender along the bottom inside.Undo all wiring from headlights,clearance lamps & any other assorted wires.It sounds worse than it is,I can usually pull the whole clip in an hour or so by myself.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
07-17-2013, 12:14 AM | #3 |
That is what I wanted to hear.........................one hour, at my age that means one day!!
07-17-2013, 02:28 PM | #4 |
That's if everything goes good& I don't get distracted.....I get distracted easy!!lol... The worst part is usually pulling the bumper off,rusted bolts can be a pain.That's when the grinder comes out..I have a overhead crane in the shop,so it makes it easy to pull the complete clip this way too...
07-17-2013, 03:59 PM | #5 |
This is So Arizona, you only have to break the nut loose and remove them with your fingers!!
07-17-2013, 08:13 PM | #6 |
[QUOTE=solidaxel;6177587]This is So Arizona, you only have to break the nut loose and remove them with your fingers!!
That would be a nice change alright,but no challenge then eh!!!! Posted via Mobile Device
07-18-2013, 01:31 AM | #7 | |
[quote=Rubble;6177982]
The challenge is remembering where I put the hardware when it goes back together!
07-18-2013, 09:39 AM | #8 |
I used to just throw all the hardware in a coffee can,now I am starting to label them.It makes it a lot easier when looking for specific bolts or screws.I have one project that's been going on 8+ years now & still not done,that one is gonna be some head scratching!!
08-05-2013, 03:08 PM | #9 |
.... What about the hood latch that is inside the cab, do I just un-hook it at the latch?
Finally had enough time and energy to tackle this engine swap! Stay tuned for more questions and solutions
08-05-2013, 07:38 PM | #10 |
yeah, just unhook it at the latch, you may have to remove the grille to get to it.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
08-05-2013, 10:06 PM | #11 |
Thanks got it !!
Fishing it back in is going to be fun !!
