Old 07-16-2013, 11:41 PM   #1
mitchell72
mitchell72's Avatar
2" shackles, no such luck
I ordered some 2" extended shackles for my swb leaf spring 72. I was not pleased with the drop. I measured and it came out to be about and inch and a quarter. Since its and original leaf spring shorty I want to keep it as original as possible. Perhaps I will remove the bottom leaf which should give me 5/8 or so. I will try to get some pics up.
mitchell72 is offline   Reply With Quote
Old 07-17-2013, 09:01 AM   #2
volksworld
Re: 2" shackles, no such luck
since the shackle only drops the rear of the spring it only lowers the truck half the amount...as you now realize....years ago I tried to soften up the rear of a race car by pulling the bottom leaf,stupidly figured it was small so it didn't do much....the end result was uncontrollable wheel hop when accelerating....since its the shortest leaf its also the stiffest and prevents the spring from wrapping up...so if you're gonna pull a leaf remove a long one
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-17-2013, 09:22 AM   #3
LONGHAIR
That is not necessarily good either. The leafs are "progressive" in length for a reason, each supports the one above it. If you leave too much space (length) unsupported, they can bend or even break.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-17-2013, 07:45 PM   #4
Mike C
Mike C's Avatar
How much drop do you want? You can get a bolt in leaf spring flip kit from Summit that will drop it 5". No other mods needed, and you can always go back to stock. Keep the shackle for a 6" drop. That's the plan I have for mine along with 2 1/2" spindles and 2" springs in the front.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-17-2013, 08:09 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I installed the 2" drop shackles and removed the overload springs on the rear of my 1972 GMC. Came down about 2.5".
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-17-2013, 09:33 PM   #6
mitchell72
mitchell72's Avatar
I removed the overload and one of the long ones, it came down a total with the shackles, about 2.5 inches. That is all the drop I am after. The truck doesn't get driven and it is by no means a hot rod. I plan on installing 2 inch coils for the front, we will see how that goes. Thanks for the input.
I may have done the flip kit in my younger days but now I want to stay as close to the General as possible, accept for headers, of course.
If I am unhappy with it in the end There are always tractor weights. LOL .
I intend on posting pics but am having difficulty.
Mitchell
