Old 07-17-2013, 12:59 AM   #1
marcolara
Questions about transmission mount crossmember
After spending a couple hours getting rid of the sludge and the dirt off my 68 frame, I discovered that the transmission mount has been cut/modified (pretty crappy job if you ask me) by previous owners. I also heard that these mounts are different based on manual/automatic transmission.
My questions are:
1) What type of cross member is this (auto, manual transmission)?
2) Is this cross member structurally safe even though its been cut this way?
3) Should I just get a new/used one and where can I get one?
Thanks!
marcolara is offline   Reply With Quote
Old 07-17-2013, 07:34 AM   #2
Lattimer
Lattimer's Avatar
Re: Questions about transmission mount crossmember
That looks like a manual crossmember. Manuals, the bell housing mounts to the crossmember with rubber isolators through the large holes. Auto's mount in the center on a typical auto trans mount.
If that was mine, I would weld some new steel on it to reinforce it and keep on rocking. I wouldn't use it as-is.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 07-17-2013, 08:27 AM   #3
volksworld
looks like some fool hacked it to get the clutch out easier...if you plan on an automatic conversion you don't need this xmember at all
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-17-2013, 08:34 AM   #4
volksworld
these also differ in shape and location between v8 and 6...a pic of the rails to show which holes its riveted to would help
