Old 07-17-2013, 03:08 PM   #1
ScottH
ScottH's Avatar
Fresh 327 short block
I have a fresh 327 short block which I bought from another board member.
Was going to use it in a project but dont have the time or money now.
Asking $850, here is the description:
1968 impala 2 Bolt main, large journal crank and rods
NEW PARTS: not installed, in boxes
Cloyes double roller timing set #C-3023X
New harmonic balancer
Sealed Power lifters(16) #HT-817
Mr Gasket chrome timing cover set #4590
NEW PARTS in assembled short block
Duralast cam bearings
Mellings standard oil pump and pick-up
Molly rings
flat top pistons
rod bearings
main bearings
rear main seal
oil pump drive shaft , heavy-duty metal
Comp Cams 12-210-2(49)
LABOR & MACHINE work
recheck all clearances and machine work
Hot tank block
paint block and oil pan
chamfer bore tops
chamfer all bolt holes
bottom tap all threads
clean, resize and install new bolts in rods
install new cam bearings
bore and hone .30 over
assemble pistons to rods and install rings
assemble short block
slide in cam, install pistons into bores, install crank, torque everything to spec, install oil pump and new drive shaft, install new pick up(set to fit oil pan)
Any questions pls LMK, pics available upon request.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 07-18-2013, 03:15 PM   #2
ScottH
ScottH's Avatar
Re: Fresh 327 short block
ttt
