Old 07-17-2013, 03:35 PM   #1
j_cifelli
j_cifelli's Avatar
lug nuts question
So I have a 1985 chevy k10 and online it says for lug nut 7/16. Some ebay items say 7/16-20 and others just 7/16. Is there a difference between the two?
j_cifelli is offline   Reply With Quote
Old 07-17-2013, 04:16 PM   #2
78maliburat
Re: lug nuts question
1985 half ton.............. 1/2 -20
78maliburat is offline   Reply With Quote
Old 07-17-2013, 04:25 PM   #3
Pop's C-10
Pop's C-10's Avatar
tha -20 stands for tha thread count or pitch..i forget which one
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-17-2013, 04:41 PM   #4
Damon23
Damon23's Avatar
This. I just bought 20 new ones last week.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 07-17-2013, 05:06 PM   #5
Katrina/10
Katrina/10's Avatar
4wd has 7/16
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-17-2013, 05:14 PM   #6
j_cifelli
j_cifelli's Avatar
item.mobileweb.ebay.com/viewitem?index=0&sbk=1&nav=SEARCH&itemId=260910760167
Thats what I ordered will they work?
Old 07-17-2013, 05:16 PM   #7
Katrina/10
Katrina/10's Avatar
Are your wheels steel or aluminum?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 07-17-2013, 05:27 PM   #8
j_cifelli
j_cifelli's Avatar
Aluminum. I got the rockstar xds
Old 07-17-2013, 07:01 PM   #9
Katrina/10
Katrina/10's Avatar
As long as you got the lugs for aluminum wheels, they should work fine.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 07-17-2013, 07:17 PM   #10
j_cifelli
j_cifelli's Avatar
The description did not say that it was for either type of wheel
Old 07-17-2013, 10:49 PM   #11
Katrina/10
Katrina/10's Avatar
Some of them are a little different, but you should be ok.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 07-18-2013, 08:17 AM   #12
Keith Seymore
Keith Seymore's Avatar
Just to re-iterate what was already mentioned:
1/2 ton 2wd = 1/2" lugs quantity of 5 per wheel
1/2 ton 4wd = 7/16" lugs quantity of 6 per wheel
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-18-2013, 09:41 AM   #13
LONGHAIR
Actually, since they are "single start" threads, they work out to be the same thing.
Thread count, with American sizes, is expressed as "threads per inch" (TPI)
Pitch is the distance between threads (single start). So a bolt with 8 TPI would have threads 1/8 of an inch apart.
ETA, the ones who just list the size as 7/16 assume the you know that automotive lug studs and nuts are always fine threaded.
This is done for 2 reasons.
First, the minor diameter (bottom of the threads) in larger because the threads are not cut as deep. This makes them stronger, with all else being equal.
Second, you get more clamping force for the same amount of torque applied to the nut.
Multiple start threads are completely different....and not in automotive use. They allow for more travel with fewer revolutions, at the cost of less clamping force. They are usually found on larger diameter pieces. It gives the strength of many threads but screws on quickly.
More than you ever wanted to know......lol
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
